  • Replies 58
I'd try a different gauge (decent one) and a leak down test.
But, those figures are shit, engine is about to blow son.
I had an rb20 that made 160kw stock and read 110 across the board, still going today without issue. Puffed a bit of smoke when cold but still made power and ran fine.
Moar boost to compensate
Do this and run a thicker oil.
what about if the car has some aftermarket cams? wouldnt that make the compression drop , my first car had the cam reground and the compression fell from 150psi to 110psi,
It will reduce dynamic compression.
Edited by Rolls
Engine is out (alot easier than i thought), looking down the spark plug holes i can see a few things on the pistons like 0.10 and "std" and what looks like a part number would this indicate it has been rebuilt previously ? also the block is painted blue.
Could the valve damage be caused by valve float at high rpm enough to hit a piston and force the cam to jump back a tooth? just a stab in the dark as it was %100 spot on before hand and definatly only jumped one tooth
You will never get valve float bad enough to smash a valve especially multiple valves.
aswell as static compression
How? The cyclinder shape is the same hence so is the volume of the cylinder as you haven't changed the stroke. Sure it will fill better, but the static compression has not changed.
Edited by Rolls
It used oil when i was running a 5-40 oil but then i changed to 10-40 and all was good,
When it $hit itself I was running my highflow at 15-16 psi at an AFR of about 12.0:1 at WOT ( was asking alot from that ceramic exhaust wheel lol ) as soon as it happened my first thought was my turbos ended up in my exhaust or its pingged to death possibly because i switched to vortex 98 from ultimate 98, i never even suspected this sort of thing happening
Painted blue block, it's been out before. I would be questioning those relatively low kilometers!
they're standard size pistons and probably original. blue block means its been out of the car before (assuming its painted everywhere?) though.
cam timing changes staitic compression too as the valves shut at different points and therefore there'll be different amounts of air in the cylinder when it shuts.
Different amounts of air yes, but the compression RATIO is still the same. It doesn't matter if you double the amount of air in the cylinder, it still compresses the same ratio.
What you are talking about is dynamic compression.
Edited by Rolls
maybe we're not on the same page, im talking about static compression figures as in what you'd get with a compression tester. when it comes to the actual compression ratio your right, static remains the same, sorry.
Yeah I get you, a compression tester is testing dynamic compression though as the engine is turning over and breathing. Static compression is simply maths, you can't really test it.
Turns out i need a new clutch i wouldnt be comfortable putting this one back in the friction plate is pretty worn and a little torn up, i thought it might be it slipped really bad on me while dropping it in 2nd around a tight corner on a hill didnt grab till it hit about 6000rpm and smelt horrible! its an NPC clutch with an exedy friction plate
Okay well got the head off today and its slightly more damaged than i thought
Turns out cylinder 4 piston is no longer connected to the crank! im guessing the bottom of the rod has come undone / fallen off and at the piston has tried to exit the engine via the head bending 3 of the 4 valves on that cylinder and forcing the cam back a tooth on the belt
The bore is still good can still see the hone marks pretty well and no scratches so thats why im guessing its the bottom of the rod that has let go
The block is rooted so is the crank and head
The rod is in 4 bits, the piston skirts are non existent, the gudgeon pin is cracked in half, the bore and crank have large gouges in them, the bottom of the bore has a chunk broken off it, the oil squirter is snapped off and the rod bearings are twisted and mangled
Cause of failure: Rod bolts snapped
Edited by Slattery Gts-t
Ouch, sorry to hear it. On the upside you can now build it (or get it built) the right way and enjoy some reliable motoring.
Chuck Norris can.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
