"think this should be here please delete from other forum"
guys just looking for some re a shorance, decided id do a service on the old rb 26 today so went up to the store grabbed oil and filter and what not sure enough dumped oil, changed filter, and fired her up. NO oil pressure only idle for about 10 15 sec. switched off, thought maybe just cause id drained the oil, the pump hadnt picked up yet, fired her up again 10 15 sec couple of short revs 2grand tops, still no oil pressure. shut her off open the door and sure enough the oil filter had blown off! oil absoulutly every where and i am pissed. turns out the filter that was in the box wasnt the filter written on the box. it did tightn up but obviously not enough threads :( so has this caused damage?? ended up putting the original back on and firing up oil pressure straight up and sounds fine but what are the chances??
thanks guys.
https://www.sau.com.au/forums/topic/380745-possible-engine-damage/
Will be fine mate. Might need some degreaser but ;)
well thats good to hear thank you so much. an im looking at maybe one of those 5 litre drums of degreaser just to get started lol, such a mess and now need more oil :(
Did you just buy the filter? Id be ringing the shop straight away advising them of this. Cover your self incase there has been damage
yeah called them, they were like well its on you to check the filter before you put it in. the best they can do is send a claim or some crap to the manufacturer :(
Yeah unfortunately there is no way to tell for certain for anyone here but if you get in contact with WearCheck Australia you can take an oil sample fro your next change and have it tested. If you get high levels of copper or lead showing up, then you know the answer.
The test kit costs about $40
Farout there must of been oil pouring out all over the place, lil tip for next time, leave the drivers sidewindow down, reach in and turn the key from there, that way soon as it starts you don't need to move to realize there's oil pouring out everywhere. That's Gunna b a prick to clean up man.
^^ this. Saved me when someone told me to use the wrong sized filter on the Stagea, shut it down quicksmart but there was still a good litre of oil on the workshop floor :whistling:
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
