Hey guyz
Im currently 19 and
Well i really want an R32 GTS-T however i know coz its imported and all that insurance is a killa
However i kinda like the 200sx (s14) and i know there not an imported model so would it make insurance a little cheaper??
Would anybody know??
Ps Which car would u recommend?? S14 or R32
Thanks
Joe!
https://www.sau.com.au/forums/topic/38077-200sx-s14-or-r32-gts-t/
Whatever you do... Don't buy a SKYLINE!!!!!!!!!
j/k
series 2 looks more agressive, i think thats about it. It came in 97 and 98. Personally i like the series 1.
The r32's a mad car, fun to drive, great on boost, but sluggish off boost. S14 is a bit better off boost, but it's more of a street car in that it lacks the extra sporty benefits of the r32 like stock boost and oil pressure guage, less adjustability in the seats and steering column, and a different suspension setup.
both good cars, S14 is newer, slightly safer option with service books, parts, etc..
Skylines go hard
R32 is more of a sports car, also a 6 cycl, so sounds nice are tough. I havent driven a stock one tho.
S14 is an aussie made car, that surprises a few people. Have a beautiful exhaust note on boost. The luxury model has a sunroof and airbag(s?)
I believe insurance will be the same for both cars, coz they are both single turbo coupes.
Id take the R32, or if not id take a S14a, they are worth saving a little bit longer for!
Flaps, not sure where you got that info from, but if it is correct, that did suprise me, got any links to back it up???
This may also suprise a few people.. Insurance on a R32 GTS-t about $2400 at 30% NCB through Justcar. Insurance on S14 200sx ~$4000 at 30% NCB through Justcar. I can't explain it, but going by that, your theory on insurance goes out the window ;) Considering the S14 costs ~$18k and the R32 ~$14k i know which one I would want... but the S14 is dead sexy and the SR20DET is a grat engine too.
In the end, it's personal choice.
To add: I don't think the S14 is an australian made car... It is a silvia at heart, rebadged 200sx, and in Japan came in 3 variations J's Q's and K's just like the S13. Australia had 3 models also, however unlike the JDM, all ours were turbo. Base model was Limited, Sports model had a few things like A/C and a rear spoiler, and the Luxury model came with a sunroof etc.
Well ive had s 32 skylines and just bought a series 2 s14 (97 with the differant headlights, taillights and badge) the s14 seems more fun to drive at this stage with much the same power as my first 32. Australian made??? dont think so. Also the cops dont seem to look at the s14 as much as the skyline as they were AUSTRALIAN DELIVERED, not ausie made. Insurance IS cheeper and so is rego.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
