Hey guys,
The factory boost gauge on my Rs4-S isn't working. I've taken it to be looked at by a professional and he told me that the MAP sensor was shot (see pic below). Any advice on how I can hold of a replacement would be appreciated.
Also, in my car the climate control and triple gauge cluster are swapped around. From what I've seen, the gauges should be at the top... While the car was being looked at, I asked about swapping the gauges around so that they'd be in the correct spot. I was told that I had the wrong mounting bracket in my car, and the gauges couldn't be moved up a spot because of this. Any takes on the situation?
Edited by Marshstag
+1. I did this with mine after Scotty posted the fix originally. Has worked perfectly ever since.
You can probably just invert the din bracket; that's probably how they were moved originally.
Your car didn't roll of the factory floor with the triple gauges or the bracket is from another stag (rsv?). It would have had a double din stereo under the climate control, I had the same problem when I wanted to move my climate control to the middle and put the gauges up top.And you cant just flip the bracket over, wont work you'll have to do some modifiying to move your gauges mate.
Edited by SatchiThaStagea
The sensor is probably faulty due to dry solder joints on the plug. Here is a how to for repair if you have a soldering iron handy.
http://www.skylinesa..._1#entry4953193
Sounds good, I'll give that a go on the weekend. Can I assume that it's the same for C34s2?
What did you end up doing?
mine is in a funny order too
i also have funny extra holes drilled in it
must be a jap thing
I'm not sure if it's a Jap thing or a previous owner thing :P
I just made do with what I had and ended up with the climate up top, gauges in the middle and stereo at the bottom.
theres 2 problems with trying to move the climate control,
1: the front of the climate control is a little wider than the bracket so the bracket is cut to accomodate this and;
2: where most things are mounted from the middle (stereos, din pockets ect) the climate contol is mounted from the bottom of the side
look here for my post that shows these probs
  • 4 weeks later...
I've had a look at your post and I'm now on the hunt for correct brackets... and I've found the ones below. They appear to be different from the bracket in the pic you posted. Does anyone know if they will be appropriate?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
