Nick, Still have some tourqe shirts in 2xl-3xl? and how long is delivery? I want one to take with me to japan on the 22nd?
What colour, Justin? There's quite a few of the blue Torque shirts, not many grey.
  • 1 month later...
  • 4 weeks later...
I would love to get a hoodie and shirt but im a 6XL FML is there any plans to extend the sizes on these items?
ohh and also we should all meet up to organise this 4 way girl on girl vampire experence :D
Edited by T4NK
  • 3 weeks later...
  • 4 months later...
  • 5 months later...
probably a long shot, but is it still possible to get any of the zipper hoodies?
Yep, depending on what colour and size you want (they also come in black).
  • 4 months later...
  • 4 weeks later...
how much are the SAU stickers with the R34 tail lights? put mine on over the weekend after getting it in the mail a while ago, wiped it with a towel (oops) and some letters came off. i was able to put them back on but there's crap underneath now...
also would like another SAU lanyard, missus took mine =)
You can have my lanyard. Stickers are usually $10 if I remember correctly as per club member application form. I need one too, because it has a bubble and I'm anal.
I'm rocking my eBay "Genuine" Nismo lanyard :ph34r:
We've been trying to figure out what to do with the stickers, as some people want a new design that's more exclusive to NSW, etc.
At the moment, though, our main priority is the AGM this weekend and running our next Texi day on the June long weekend.
  • 4 weeks later...
  • 3 months later...
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
