  • Replies 203
I dunno tbh.
2JZ is a drop in and go and has bigger valves etc
1.5JZ means building shit/modifying the head/block etc and I'm lazy these days
2JZ-GTE with new rings and bearings seems like the go to me
Turbos and manifolds finally off...I really feel sorry for Toyota mechanics
Lots of oil/grime on the bell housing and the back half of the block, might be leaking a little from the cam covers, the bolts were a little loose so nipped them up and I'll keep an eye on it.
Also have to figure out how to get the factory oil drain off...cant get a socket in there nor can I can a spanner in there....
I was expecting 2 drain holes in the block ala RB26...but its a steel Y piece...So I may block the rear one and use it as a crank case breather/oil return from a catch tank and use the forward drain for the new turbo...Should work well I think.
There are also the matter of the rear turbo water feed sticking out near where the new dump pipe will go, So I'll loop it into the front turbo water feed, which will be a neater solution to sticking a couple of bolts in cut off hoses...looks shit and tends to leak after a while.
Anyway a few photos of progress...Was delayed a little as a had to rescue one of my cats of the neighbors roof lol.
I'm quite happy with how it went today, only took 30-40mins to get the rear turbo off (just needed a couple of nuts removed though as most of it was done Monday)
I dunno tbh.
parts all interchangeable? like manifolds and turbos? and stuff?
loom?
mmmmnah I'll be right...Have seen a 1UZ-FE in a sprinter though ;)
fits alright, less room than it looks lol
love the 1uz swaps - its one of my projects down the line lol
i would like to see that.
then click the link :P
http://www.driftworks.com/forum/drift-car-projects-builds/58737-1uz-ae86-aus-toy.html
Chris you have more room in the bay either side than the Soarer does!!!
The front rails sit so high in the Soarers that where the engine sits is half as wide as the bay!
How are you going to fit dump pipes with the turbos like that? Are they adapters?
Did it take you long to get the intake vacuum lines all back on? there are about 9000 of them!
Well, some good news. Due to me having what looks like a 2 1/4" mid pipe I was going to try and make one...BUUUUUTTTT aftermarket ones for JZA80s are exactly the same :D
Also had a go at starting the dump pipe (the back half of it) by cutting up an old one I had here off the skyline...but it was all rusty and I ran out of grinding disks...so i decided to weld it up anyway....WHAT A MESS!!!! I wont make excuses. it wasnt cut straight enough and I got a bit carried away...really need a drop saw, as trying to cut angles with a 4" grinder just doesnt work!!!! >_<
http://www.driftwork...86-aus-toy.html
liking the red piping...
and.. wow. the amount of effort needed to make things fit..
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
    • Yeah it is wild how much wider the Yokohama A050 in 255/40R17  vs Yokohama AD09 in 255/40R17 sits on the 17x9 +22 considering its even from the same brand and adjacent product family
    • Would love to see some examples of WMI making the same as E85. Only thing I've ever found is this one.  Which suggests WMI is not worth much at all.
    • And now the washer bottle looks like an orphan. You're going to have to spend money on a wrinkle black painted fabbed ally one of those. Oh, and the brake MC res. That won't look any good after you've gotten rid of the washer bottle. You going to need to go back to work to keep up with this?
