  • Replies 48
dale, glad to hear the radiator is working fine! how much cutting was required to fit that monster/?
It wasn't too bad really; some trimming of the radiator support, and some heavy modding of the fan shroud.
The big issue was the top mounts, I ended up fabbing some offset mounts to allow the top to sit about 15mm further back.
It's a thick core though...
Slightly unrelated, but what fan shroud are people using with the Mishimoto rads?
They don't have a shroud to fit the G35 radiators, but they do for the cheaper 350Z radiators. The dimensions of the 350Z radiator also look almost identical...
Will have to modify the existing shroud, make up a custom one or switch to the twin electric fan set up and use the Mishi 350z shroud.
I was going to switch to twin electric fans, but according to Mishi the 350z shroud doesn't fit on the G35 radiator. That was the original plan.
