Right kids...
Thursday is the day for BF3 on PC! Unfortunately Thursday is also the day I head up to Shepp for the SAU Nationals >_<
So come Monday it'll be game on for me...
So who's pre-ordered? Who's gonna be playing?
I know a few of my mates, and brother are all set to rock and roll. So no doubt a fair whack of you lot are!
I will definately organise a BF3 night for us as my work and life is about to quieten down a little leading into Xmas period so intend on getting back into some games :worship:
https://www.sau.com.au/forums/topic/381146-official-battlefield-3-thread/
ill be there gaiz, usual tag of bozodos on Origin
it's not out for Aus yet either, if you're that desperate you could VPN to South Korea or something like that
just installed the newest Nvidia drivers for it (since the beta ones were making my machine hard lock up in everything!)
just lifted this from the OCAU thread, and have gotten it working on mine for early access:
Control Panel -> Internet Options -> Connections -> Lan Settings (Bottom of the Panel)
Tick "Use a proxy server for your LAN" Address: 210.107.100.251 Port: 8080
Click Okay. The via ORIGIN start BF3 and it'll unlock. Then untick "Use a proxy server for your LAN" and you are good to go.
My stupid CD key site says I won't get my key till the 27th.
This is, in reality, a good thing as it will prevent me failing this week's uni exams :P
I'm sherbert86 on origin if anyone wants to have a game over the weekend though :)
haha I was wondering why you keep playing the Russian version Madaz!
Turns out that something to do with my GTX 460 SLI setup is causing an issue; solid as a rock on one card!
Single player is pretty good, but too scripted for my liking, multiplayer is fkn AWESOME! (would have liked more destruction but I guess there are limitations to that)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
