i didn't get that feeling
Maby it's Just the lack of fog of war but then Oman never really had fog and bf2 seemed alot Bigger
sharqi without the fog seems small especially when your gunner in the cobra and you spawn looking at the mi28 but then when running around seems better
Karkand is epic
Wake is good
Would of loved the colors to be brighter and not washed out
And the f35 is so crap and has the potential to make wake the same as bf2 as the way it handles it cant hold it's own in the air and any avg pilot in the su35 can take out even the best pilot in the f35
Edited by Damit
Happy to orgynise for Thurs. Its the only evening I'm not out this week.
Given you've decided to have b'day beers tomorrow you unorganised kent, and I'm busy on every other night until next week. :thumbsup:
You shouldn't need anymore than 24 hours to decide if you want beers or not :P
Maybe I'm not with it but I've been playing today and last night and I spawn and just get raped within 2 minutes, lucky to even SEE who killed me. I still haven't ranked up yet, anyone got some tips/tricks for beginners? I'm struggling to get into this game and am tempted to put it on the shelf indefinitely.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
