we use Pro Con for managing our server but having a look at the link you posted
Have not used the new version of pro con so let me know what you think if you end up using BF3CC. I have had bo problems with it yet.
it keeps disconnecting every 30-45 seconds it auto connects again but takes like 20 seconds
EDIT i do like the UI its nicer than ProCon and i can very easily change my mapcycle and gametype where you can do that in ProCon, but it isnt reading from my banlist that is already on the server
BF3 better than MW3? (online play PS3 is what I'm interested in).
That depends on what type of game youwant to play. BF3 is more team based with bigger maps and morevehicles and MW3 is more of a run and gun type game.
Sort oflike Counter Strike but war based. I like the team based type wargames and more realistic game experience so I will always play BF3just like from the start..
Strange.. unless it is because the sever has Pro con start up file?
Mine never disconnects only if i do a server reset. I just had a look at pro con it does have some functions that BF3CC does not but it seams like a bit more work to setup server map wise at least.
Strange.. (1)unless it is because the sever has Pro con start up file?
Mine never disconnects only if i do a server reset. I just had a look at pro con it does have some functions that BF3CC does not but (2)it seams like a bit more work to setup server map wise at least.
(1) no, procon isnt installed on the server its running on my maching and the server is a gamearena one
(2) yeah we change our map cycle through gamearena's website as they give you access to all the important files
Damian is it an actual download or a webclient
either way i cant figure it out
it is a web client - everything runs off the server and you access via the web works perfect on my iphone as well
i love it as i dont need to leave my PC on anymore - especially since its so hot ATM and it is in my room - there is a charge for it now but only a few $ and makes it easy to manage and give all the admins access and the use of ingame commandsand the plug ins
Edited by Damit
Thanks man, will pick it up at some stage.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
