hey ppl, ive put in some gauges on my 32, got a oil temp gauge and oil pressure, now with the oil temp its take for ever to go up like afta 30min of driving though traffic is starts to go up but really slowly, is that normal or is my temp sensors slow to read? am i able to use a unversial sender?
2nd the oil pressure is fine till its warmed up, sometimes i stop at the lights and my gauge reads 0? i keep my eye on the orgnial oil pressure on the cluster and its different readings, ive t pieced into the orgnial hole for oil pressure in the block
these are all saber gauges
https://www.sau.com.au/forums/topic/381183-need-help-for-my-gauges/
Doesn't sound right to me. My oil temp doesn't start till 40' [from memory and too lazy to check] but it starts working within a couple of km's so like 5 minutes and its slowly heating up. Settles on around 85 to 90'. Oil pressure never drops to zero, sits around 3.5 to 4, drops to around 2 [usually 2,something, maybe 2.2???] at idle.
All the senders look the same, but they are for different ranges. You would be better off getting another Saber one just to be sure.
mine are greddy gauges - takes about 5 mins for it to start moving - 10 mins its usually at 55-60 degrees Cel.
depends what gauges you buy - those saber gauges, i dunno.. never used them but for 50 bucks i guess you get what you pay for.. factory gauges arent that accurate..
I've only got cheap NRG malaysian electronic stepper motor gauges and they work fine. They do a whole of range and scale check every time you turn them on, this helps with setting baselines and accuracy. I haven't heard anything bad about Saber gauges, they're probably OK.
I had Greddy gauges, they were analogue ones, sold 'em, too many hassles with them.
You say you've 'T'ed the pressure in at the sender, where have you picked up the temp?
I've got a sandwich plate at my oil filter that has adaptor holes in it for both temp and pressure, so the oil flows past both senders all the time.
If you've got yours in a dead end spot you may actually only be measuring the block temp instead of the oil temp? This would expalin the slow response.
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
