hey ppl, ive put in some gauges on my 32, got a oil temp gauge and oil pressure, now with the oil temp its take for ever to go up like afta 30min of driving though traffic is starts to go up but really slowly, is that normal or is my temp sensors slow to read? am i able to use a unversial sender?
2nd the oil pressure is fine till its warmed up, sometimes i stop at the lights and my gauge reads 0? i keep my eye on the orgnial oil pressure on the cluster and its different readings, ive t pieced into the orgnial hole for oil pressure in the block
these are all saber gauges
https://www.sau.com.au/forums/topic/381183-need-help-for-my-gauges/
Doesn't sound right to me. My oil temp doesn't start till 40' [from memory and too lazy to check] but it starts working within a couple of km's so like 5 minutes and its slowly heating up. Settles on around 85 to 90'. Oil pressure never drops to zero, sits around 3.5 to 4, drops to around 2 [usually 2,something, maybe 2.2???] at idle.
All the senders look the same, but they are for different ranges. You would be better off getting another Saber one just to be sure.
mine are greddy gauges - takes about 5 mins for it to start moving - 10 mins its usually at 55-60 degrees Cel.
depends what gauges you buy - those saber gauges, i dunno.. never used them but for 50 bucks i guess you get what you pay for.. factory gauges arent that accurate..
I've only got cheap NRG malaysian electronic stepper motor gauges and they work fine. They do a whole of range and scale check every time you turn them on, this helps with setting baselines and accuracy. I haven't heard anything bad about Saber gauges, they're probably OK.
I had Greddy gauges, they were analogue ones, sold 'em, too many hassles with them.
You say you've 'T'ed the pressure in at the sender, where have you picked up the temp?
I've got a sandwich plate at my oil filter that has adaptor holes in it for both temp and pressure, so the oil flows past both senders all the time.
If you've got yours in a dead end spot you may actually only be measuring the block temp instead of the oil temp? This would expalin the slow response.
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
