My skyline is gone so all the bits and pieces I've accumulated are up for grabs. If no one wants it, it goes to the tip.
This list of items are free to good home and available for pick up from 4032, Brisbane
R32 GTSt intercooler with one pipe (hot side I think? have no car to reference to)
R32 GTSt intercooler air guide
R32 GTSt air intake (from behind headlight)
R32 GTSt intake-to-airbox joiner
R32 GTSt lower bumper inserts
R32 GTSt front active spoiler and motors
Pod filter, 3"/75mm
3" to 2.5" adaptor for pod filter
Double DIN storage with flip lid
I also have at my parents place in 2226, Sydney:
R32 GTSt factory exhaust (turbo to tip)
R32 GTSt airbox (lower half only)
R32 GTSt front pipe (between dump and cat)
https://www.sau.com.au/forums/topic/381506-free-stuff/
Hey Roy, you can't receive more PM. I live in Chermside which is quite close to Virginia - if you want your friend can give me a ring and come round over the weekend, otherwise I'm usually home after 6 during the week. IC shroud is yours for the taking but already got the other bits set aside for someone.
Jimmy, I can post you the storage thing if you want - probably cost about $5
https://www.sau.com.au/forums/topic/381506-free-stuff/#findComment-6104749
Update on available things:
Pod filter, 3"/75mm
https://www.sau.com.au/forums/topic/381506-free-stuff/#findComment-6119611
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
