rb30 series 2 motor brisbane. will drop sale price to $150 WILL NOT SELL FOR LESS THAN $150
selling this rb30 motor in the pictures. $250. told it had 150 000kms. is out of a vl. has oil and water holes in it if you wanna put turbo on it. i bought it to use but never did.
bought it to replace one in mine but am building in the old motor again so dont need this one.
what you see is what you get. motor is good to go.
have a hoist ready for you to drive your ute or trailer under and take it away
so buy it $250
pm me
located northside brisbane
https://www.sau.com.au/forums/topic/382176-rb30-series-2-motor-brisbane-150/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
