Stupid clutch fan is trying to keep up with my engine rpm. Its the second one I've put on my car since I bought it 2 months ago... Sounds like crap and takes power away from the engine.
Only happens once engine is warm and on warmer days.
https://www.sau.com.au/forums/topic/382212-i-hate-clutch-fans/
[quote name=ClutchBurndout-:(' timestamp='1320561346' post='6097171]
get new clutch fan
I know i need a new one, I was just venting lol. I have the worst luck with them, I reckon I have bought maybe 4-5 over the years on many various cars...
My R34 used to do that too on warmer days - 40+C - but I'm guessing it was to keep the car cool..
Chuck consult on there and make sure your coolant temperatures are still good. Mine were hitting 100+ - turned out my thermostat was toast. You cannot trust the factory gauge, on mine it was still displaying the regular 'half way' when at 100+C.
properly installed thermos are the way to go. pull type, sealed and shrouded, on with ignition and you will never have a problem. plus youll gain a bit of response due to drag of the fan on your crank.
most people wont bother with the hassle of hooking it all up and making it work on a street/daily but its a great upgrade out on track!
Edited by SkyHi_33
I had x2 davies craig fans on my seven, push and pull setup, worked great but 4-500 bucks worth from memory. I got a feeling JRM might be onto something there and my car is running hotter than my guage says, need to suss out my cooling system before making any purchases me thinks
Random factoid - for all the work Nismo did for the R1 conversion (a package specifically designed for the track) on my R34 GT-R, they don't replace the factory fan setup, they just upgrade the radiator. I've driven it in traffic on a 40 degree day and it didn't skip a beat, never got above 90 degrees. It coped in the heat far better than I did...
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
