Hey guys & girls
Looking for a good place in Perth to install a Mongoose M80G alarm and know what they are doing with it.
Had some stories where things went wrong when not done properly with this system. Any recommendations is much appreciated!
Cheers
Amon
https://www.sau.com.au/forums/topic/382253-car-alarms/
without name dropping a certain car stereo place assed mine up, twice, and still didnt get it right. wherever you go, check they have soldered the wires not just wound them, and make sure you dont have meters of wire just left hidden under stuff. personally from my experience, id avoid places that are basically car stereo places as they are generally 16yo's who dont really know wtf their doing
https://www.sau.com.au/forums/topic/382253-car-alarms/#findComment-6097931
Yerp I've been caught out by a business before.
They installed the alarm. 3 weeks later it kept going off. Their installer looked at it and said he didn't know how to fix it. And that was it. Brilliant. Stuck with an alarm that goes off for funsies.
Ended up going to Action Alarms in Osborne Park (No sure where they are now?) and they put a whole new system in. Best alarm ever.
https://www.sau.com.au/forums/topic/382253-car-alarms/#findComment-6098247
I have used them twice. They did my R34 GT-T, came to my house and wired up the alarm including built in turbo timer. Then when I imported my Mitsubishi Legnum VR-4 they came to the compliance workshop and fitted the whole thing.
Excellent product and customer service.
https://www.sau.com.au/forums/topic/382253-car-alarms/#findComment-6098574
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
