  • Replies 55
This sounds like one of those brain teasers
So turboadam are you saying a single point on a larger circle wil still take the same time to travel a full rotation than a smaller circle?
Common sense would assume the larger circle takes longer to rotate
Edited by domino_z
Your rim has a smaller circumference to your tyre, but of course they both take the same time to complete one rotation otherwise your tyre would be spinning on the rim. The cap in the center of your rim also takes the same time for one rotation. The speed is the variable as the circumference increases.
EDIT: I have not received anything offering suspension updates for an MY11 to this new asymmetric design.
Edited by OzStriker
my brochure for my 2010 says $4990 for the brake upgrade and $13xxx for the brakes + suspension
nissan must have changed the calipers 2009 to 2010
the extra 10mm on the 2011 discs comes from wider hats and then a different bracket bw the caliper and upright to push the caliper out 5mm, otherwise us 2010 owners wouldnt be able to re-use our existing calipers + pads in this kit
so the extra braking performance 2010 vs 2011 isnt really from increased surface area of the disc as one would initially think, but rather from the increased cooling effect by taking a longer cycle for the disc to travel one full rotation under the pad
when im due for front discs, ill just order the new caliper bracket and larger discs as 2011 spare part like i did upgrading my M3 brakes to the larger CSL discs
I'm confused now as to what the differences are between the 09 and 10 brakes for the $5K difference in the conversion..... And if the main change between the 10 and 11 brakes is just a caliper spacer then what do you change on the 09 to go to 11?. Calipers, pads and spacer? Can't imagine that if they're charging $5K for just the spacer that a caliper and pad change will add "only" another $5K. At the drive day Mizuno told me that a spacer was all that was required but I don't recall that I had mentioned it was from an 09 to an 11. He would probably have assumed a 10 to an 11. What's interesting is that when I bought my 09 I was told that a complete brake pad and rotor change would cost $20K for front and rear brakes, it appears now that if you wanted to go down the OEM path it will cost you no extra to convert to the MY11 brakes than what it would have cost to just re-rotor and pad your 09 back to original brakes!
And the increased cooling is primarily due to the increased surface area and (thermal) mass of the rotor. There is increased braking force for the same amount of brake pressure because of extra leverage due to the centre of friction being further away from the rotating axis but this does not improve temperature performance because the same energy is being absorbed by the brakes anyway you cut it. You are actually correct in a way about the "time" aspect even though you didn't state it clearly because if the pad length is the same yet the rotor is increased in circumference the size of the angular arc the pad covers is actually reduced therefore any point on the swept part of rotor surface actually spends a greater percentage of the rotation period time exposed to the air and less time under the pad undergoing friction and warming up thus improving cooling efficiency. It's effectively a change in the duty cycle. It's not hard to visualise if you just exaggerate things up to bike tyre size etc for it to make more sense.
Edited by fungoolie
09 upgrade includes new calipers
10 upgrade does not
i did a similar upgrade on my m3 when i was due for new front discs. i went with the larger csl front discs and they came with a different bracket bw the upright and caliper - caliper and pad are identical
i doubt the change in r35 caliper is a mounting issue. id assume its some internal change they made to the caliper itself, and in "upgrading" nissan figure you're better off with the newer improved caliper - remember there is a visual difference bw the 09 and 10 caliper in the lettering on the face
Edited by domino_z
doubtful
the rear seat delete means it'd have to be classified as a 2 seater - which means Nissan Aus would need to ADR it again ?
the bigger issue though is the Aus rrp - Nissan Aus in the 2011 model are now bringing in the base model Japanese GTR (all black seats and grey roof lining) to keep the currency exchange price rises as low as possible for the end consumer
this track pack would be pushing mid 2s easy
Edited by domino_z
1323507657[/url]' post='6147318']
http://www.motorauth...-launch-planned
do you think we'll get it?
Some people are working very hard to make it happen, there is a good chance we will see it in Australia!
  • 3 weeks later...
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
