We've all been talking about it for a while - but it seems Jetdat, Cr34tion, Hotsky, SSGohan, Funky, me - and probably some others all work/live near the BMW dealer on cnr Kingsway/Dorcas St.
So... I think a coffe & catch up at the Smoothe cafe (downstairs next to BMW) is in order. When? Well... i'm here every day, so lunch/after work is fine. What suits everyone else?
J
  • Replies 54
well i was thinking of starting this thread but you beat me to it..:)
i am ok for lunch or after work as long as it is organised in advance...
by the way James perhaps you can bring my tshirt along if thats ok?
cheers
you guys should hit the Belgian Beer Garden out in prahran
i work at the alfred hospital and that's just around the corner and now that i'm off my P's we should have drinks there one week if you are interested (i havn't met any of you really)
well next fri sounds cool to me...considering i just have to wander down from level 5 upstairs after work hehe...smoothe cafe is all good especially the cameron diaz look alike waitress in there!
hotsky...
i know the girl you are talking about....:)..
I'll have to drag myself over from the big stone walled place on St K rd for a coffee. Name a time, I'll make it, even though I spend a lot of time at home right now, i do need to come in occasionally.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
