Hey guys,
Got some things I really don't need lying around:
2 x R32 Tail-lights (White Surround, Ie Both Sides) - $150
2 x R32 Windscreen Wiper Motors - $25 ea
1 x Passenger R32 GTSt Seat (On Rail) - $120
1 x R32 GTR handbrake - $10
Various Interior parts:
- Centre Console - $50
- Part that goes around the dash cluster - $10
- Part that goes around the centre console - $10
1 x R32 GTR ABS unit - $200
1 x R32 GTR Alternator - $100
1 x R32 GTR Starter Motor - $100
4 x R32 GTR standard Suspension (full set) - $300 ono
Give me some ballpark figures. You know what most of these parts are, but if you are interested I could get pics. Some parts may not be suited to freight.
Thanks,
Rick
https://www.sau.com.au/forums/topic/38250-r32-parts/
Hey guys,
Sorry about the delay, I have been busy.
Its not the panel that goes around the gearbox surround and up around the cluster/gauges/stereo. It goes BEHIND the dash, if you look at your interior side on you'll see a panel going toward the front of the car, on both sides of the middle of the dash, and thats it :D
You might have a boost controller or a turbo timer or something stuck to the side of it..
lwells: Sorry, don't have them :)
Nismo_286: Yep, got that complete in one piece, $50 :)
https://www.sau.com.au/forums/topic/38250-r32-parts/#findComment-775261
NickySantoro, do you have the part number of the ABS system on a 33GTST ? Knowing Nissan they'd be the same, but it'd be good to be sure.
CerealKiller, the condition is average, a little bit of wear but its not really peeling off. Looking at the windscreen wiper motors, I've got 1 x front and 1 x rear, so this one is avail to suit yours if you want :mad:
https://www.sau.com.au/forums/topic/38250-r32-parts/#findComment-796360
Appreciate it man...
Once i see the pic, i will reply back to you...
Cheers.
Sorry Nismo_286, been busy, i'll post up a pic of the thing tonight.
I'd prefer not to bucher it but I spose $20 plus freight if you want it, its in good condition.
Cheers,
Rick
https://www.sau.com.au/forums/topic/38250-r32-parts/#findComment-796667
  • 5 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
