Boost Controller
11 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
there was a really good write up on EBC's on here from a few years back...but I cant for the life of me find it
Basic gist was that a good EBC was worth 30 odd kws through the mid range over a bleed valve and full boost about 500rpm earlier.
I been reading heaps about them.
The electronic are way more reliable as they dont have as much boost spike and overboosting issues.
Zebra is yours the one with no screen and just the push in push out button?
Currently running a boost t and find it seems okay but just never seen the difference of it compared to electronic
Currently mine has a manual one installed. It has the switch in the cab for high and low boost.
Apparently the low boost cant go below 6psi, it is as low as it will go (on the unit i have)....and the high is set around 11psi.. However, it is easily bumped and changed... I bumped it the other day cleaning under the hood, so now need to see where it is sitting at and make sure it is not too high......
I definitely get boost spikes atm, and I am pretty sure that is not really a good thing... On low, it spikes near 10 then averages back to 6 or 7 psi... on high, it spike to 14/15 and then averages back to 11 or 12 psi normally.
The prob is either of these things are not technically rego legal, at least not in the ACT.... I cant see why if they not legal if they are done properly and safely and dont ventilate to the atmosphere though.... An electronic would be even more awesome, but that would prob take a lot more setting up and costs to get..
Also, what is the deal if i ever need to take either out.. (the manual or an electronic) to pass rego? Wouldnt that mean i have no boost limiter at all?? And would it even be easy to remove... esp an electronic... the manual one seems to just splice in to one of the lines? I need to look at it better some time and learn more about how these work....
Edited by J'son
to take it out, just run the boost source straight into the actuator, will give you 5-6psi max (actuator pressure)
For those who arent quite sure about boost controllers, wastegates, actuators etc
It is quite simple.
internally gates turbos (like the standard RB units) have an actuator
looks like this
inside the can (big round thing on the end) is a spring and a diaphragm
the spring holds the flapper closed
looks like this
via the rod on the actuator (long bit with a hole in the end)
There is a nipple on the can that is feed pressure from either the intercooler piping or the intake plenum.
When the air pressure in the pressure in the can is greater than the spring prssure it opens the wastegate flap and bypasses exhaust from the turbos exhaust wheel which stops the turbo from spinning faster and faster (which if happens you have unlimited boost...well unlimited until either the engine or turbo goes bang)
But as the air pressure increases the valve slowly starts to open, as both the spring is effectively loosing tension as the pressure builds up on the diaphragm and the exhaust gas pressure builds up behind the flapper it isnt a straight hits 7psi and snaps open
A Manual boost controller or bleed valve simply reduces the amount of pressure the can receives by bleeding off though a needle valve (if you looks at the bleed valve there will be a little hole in it somewhere) and tricking the diaphragm into thinking there is less pressure there so the spring holds the flapper closed more than normal, allowing more exhaust gas to go through the turbine wheel and thus increasing boost.
Electronic boost controller works in the same way, but has an electronic solenoid which pulses to let the air out.
They bring boost on faster buy leaving the valve full open (hence the can not receiving any pressure and holding the flapper fully closed). Until it gets close to the target boost pressure and then starts to allow the wastegate to open by bleeding off less air and sending more pressure to the can.
The cheapest manual boost controller out there is to simply poke holes in the vacuum line going to to the can.
(we used to do this at dyno comps on the 2nd and 3rd runs in events where you werent allowed to change the state of tune between back to back runs)
We would "check for leaks" and poke a few holes in the boost controller hoses with a pin and hello 4-5psi more with out changing anything :whistling:
NB* I dont recommended doing that though as quite a few engines went pop because it got too much extra boost as it cant be controlled lol
Wow I need a break....will explain boost spiking in a few mins
HHHokay
Boost spikes:
Manual controllers a notorious for it (especially the Turbo Smart ones)
Basically, turbo ramps up to max boost faster than what the actuator can open to slow the turbo down usually caused by vacuum lines that are too long and delaying the pressure the diaphragm gets to open the flapper, or a bleed valve that bleeds off to much air in a big rush when the pressure goes up before settling down.
EBC's can do the same, which is why most have a gain setting which is basically a frequency controller for the solenoid, turn gain down allows more air to reach the can earlier.
Boost drop off:
Caused by lots of things,
1. a weak actuator spring which means the flapper is blown open by the exhaust gas
2. Restrictive exhaust, as pressure builds in the exhaust the turbine slows down, think of a desk fan, spins pretty freely in fresh air yes. put it underwater and see how fast it spins. exhaust back pressure does the same thing
3. too small turbine housing, pretty much same as above.
4. Bad tune, too rich and too much timing means exhaust gas temps are low and the exhaust gas doesnt have the energy to drive the turbo hard enough (common with really big turbo setups on small engines)
5. Gasket/intercooler piping leaks, speaks for itself really...leaks are bad mmmkay
6. compressor out of flow, the turbo simply cant pump enough air into the engine as revs rise.
Boost creep (boost keeps rising)
Also cause by a few things
1. wastegate too small, cant bypass enough air, turbo spins faster and faster (often found with Gt30 turbos with the .63 A/R exhaust and cheap ebay turbos with internal wastegates)
2. Tune, not enough ignition timing means a very high exhaust gas temps which spin the turbo harder...usually goes hand in hand with a too small wastegate.
3. Bad boost control - bleeding off too much air
4. Wastegate flap being stopped by the dump pipe, usually found with cheap split dump pipes, the flapper gets jammed and cant open any further due to a bad design
You can of course get a different spring which is set to a higher pressure.
But this means pull it all apart and can get messy/expensive. (not to mention its not worth the time)
Zebra thanks for all the info I wish I could rename the title so people can get access to this info.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
