hi everyone,
ive been umming and ahhing about going e85, and seeing how its going to run 30% more flow, fuel system is the first thing to look into. used the search and googled alot but no definitive answers. here is my current shopping list:
vehicle: 33 GTR
- 2.5L surge tank
- 2 x bosch 044 pumps
- intank for lifter pump
- aeroquip fuel hose pushlock for within boot (becuase had heaps of fittings to suit already)
- braid for everything else
- required fittings
- twin entry fuel rail
- ID1000's
- Nismo FPR
1st question: what size lines should i be running to and from the engine? ive heard of people running the 044's into the stock supply and return lines and run a new return hose from the FPR back to the tank. ive read that the stock fuel lines are about 8mm, but how would i get a fuel hose from the 044 to the stock lines? i understand would be easier to just run everything new.
2nd question: the new fuel rail is a Trust one, centre return is a -6. how do i get that onto the nismo fpr where the opening seems alot smaller. on same topic, what size return fuel line should be run? -6? -8?
im planning to do all this myself to save some coin, any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/382844-fuel-setup/
Lines are as fallow:
-6an for up to 600hp
-8an for up to 800hp
Etc
This is the usual way to determine what size of lines to run.
Basicly that is.
Use your oem line to your external fuel surge tank and run the 044 from the surge tank to the fuel rail
I have never run corn fuel or what ever so might way to ask your local tuner what's best.usually you need to run larger injectors ect then what you will need to run on pump gas
2- dont use a Nismo fpr
Use a sard
Problem solve
Edited by koe
https://www.sau.com.au/forums/topic/382844-fuel-setup/#findComment-6107565
Mate i have the same setup as you described on my Built 26 running E42...
Bosch 040 intank feeding the 2.5l surge tank
i have twin -6 Teflon Braided lines feeding each half of the sard rail with one 044 for each line... i am using a sard FPR witch returns down the stock steel lines conected to the center of the rail.... ( removed all the flex rubber fuel line because ethanoll eats rubber and replaced with ethanoll resistent stuff or Teflon Braid)
This car has been making 600hp on pump fuel for 3 years and is now on e42 making 555hp with 5psi less boost (20psi)
https://www.sau.com.au/forums/topic/382844-fuel-setup/#findComment-6124538
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
