  • Replies 105
Posted Images
lol nice! he had a fair crack in that FC though, that thing looked like it had no traction all day haha
I had 4 bad tyres on. Previously ive just swapped off the rears and it worked well. This time i had no front grip and locked up if i thought about breaking. Still had fun doing skids.
Protip: keep reasonable front tyres on when going to texi.
And finally i get footage of my car spitting fire - around 1:03 for those playing at home. Thats made my day Eric :banana:
hhahah thats a good idea
any news on the car?
On my car?
I lost second gear synchro and my catch can filled up and put some oil through to the intake..... But other than that she ran very well, she kept all the cheater cars honest
Whoever owned that WRX, champ of a bloke, and a bloody good driver! In the second video I'm glad you got the launch of thr GTR. That appears like the second time l battle you I think where I didn't botch the launch... Lol
I got the vid of me frying my tyres but its actually quite boring. So unless some people actually want to see it I won't bother uploading it. My Gopro stuffed up too so all my vids have the sound out by like half a second. Really annoying!
Thanks to the organisers. I would've liked to stay around and help clean up but had to take my mate home because he had work that night.
Good fun. But kiddies don't do what i did and keep going after you've shredded your tyres. Doesn't work out too well.
Paint damage to rear quarter panels happened to 2 cars when the tread body tore away from the carcass, little steel wires in the belts do a bit of scratching!
We may look into some sort of plastic adhesive protective wrap to put over rear guards etc for a little coin, if you wish to really punish the tyres on the course....
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
