Just drive it nicely and you'll have no problems.
Have you just run the intake direct from the turbo to the inlet? If so brilliant throttle response!
yep direct from turbo to intake, its like accellerates before i put my foot down cause its that quick lol j/k but its almost instant power and spool just makes the engine run between 1/2 and 3/4 when boosting up hills and stuff, more boost higher the needle, hopefully my 800x300x76 fmic will help bring the internal temp down and icrease some hp
i was running my rb20det with no intercooler only around the block as would have big problems with changing gears, major power loss to the point of almost stalling/ cutout.. fitted the fmic 3 weeks ago and made the world of difference, reduced the over all running temp and a huge difference in power with NO cutout...
excellent great to get some feedback, should have my fmic by the end of this week, then boostin away till my hearts content, runs bloody good as is though, but feels like someones got there foot gently on the brake till 3 psi then there is a sudden power gain,,, and no its not just the boost gain, fells like an extra piston kickin in but its runnign smooth as??
Guest INASNT
That size FMIC is a massive overkill unless u r planning on running a 800hp turbo.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
