As long as a external gate is plumbed back and not vent g it's legal I'm currently going through engineering process here in WA and as mentioned by my engineer as long as it's plumbed back your safe
Lol yeh I know, my comment was a jest about Nathan's gate setup.
  • Replies 53
What effect does the turbine housing and wheel have on scavenging?
I am not sure your comparison is applicable at all.
Are you sure you know what scavenging is? The turbine housing and wheel have very little effect on that.
Who drives a turbo car off boost anyway?
The only off boost you should have, is waiting for the lights to go green...
I'm sure most people drive off boost. Any time at all I hit full boost regardless of the speed limit there are 2 black lines out the back. So it is off boost for me thumbsup.gif
wow now your telling Nismoid how important it is stay legal when he is pretty much the spokesperson for having a legal or under the radar car...
you know Ive have many, what could be called illegal mods but Ive never had any problems, even when pulled over for rbt...
and Im not a grandpa driver so I dunno, dont hang with hoons I guess.
I'll go with the biggest cat, is half an inch really going to make that much diff in a negative way..
WOW!!! Spokesperson my butt. If he was the legal dude you say he is then he would be recommending the OP a legal cat wouldn't he. Not just contradicting my posts with nothing useful to add. Much like the majority of the people commenting on this thread.
So where was your useful advice again?? Oh wait there wasn't any...
There's nothing illegal about having a 5" cat though. If a car is too loud, I wouldn't go about fixing the problem by using a smaller cat. One or two good mufflers and it will all be legal without causing too much of a restriction.
And let's face it... If a cop wants to sticker you, there's plenty of other things they can get you for.
That's it majority of the time cops will sticker you even for parts from factory that they believe are defects they are that dumb they don't know what they are looking at they only need to pretend to once the stocker is on it's up to the pits which it's them that pick everything
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
