I have a problem with my BNR34 UK-Model with Link Ecu
I have no 4wd and A-LSD and the fail code 72 (TPS)
After I bought a new TPS I wanted to calibrate it and now the problem.
I can only calibrate it like in the BCNR33 manual (0,4 and 3,8 Volts on Pin38) but the BNR34 manual says I should calibrate to 0,5 and 4,2 Volts. But this isn`t possible at max I get 3,9 Volts or so and this dont fit at idle....
next problem, my mfd showes around 50% at full throttle. So I checked pin 56 and there I have 0,25 Volts at idle and 2,1 Volts at full throttle. but this should have 0,5 and 4,2 Volts or not?!
What is going wrong there?! =(
__________________
Good build thread man. 1 thing I didn't quite understand is why didn't you go for a reasonably sized single turbo setup instead? I had my last R34 GTR with -5's and now the R32 with -5's, both are laggy as f**k. And went in my friends R32 gtr with a single T04Z setup and 2.8L engine, the thing has lot more response! You did a full hearted engine rebuild so wouldn't it be better if you ditched the twin for a decent sized single turbo setup? That way you would have got more top end power with better response and less turbo lag. Just my personal opinion... :)
Edited by G0Z1LLAAAAA34
  • 1 month later...
After problems with my Link ECU and the AWD System I got my revised ECU back. Its all fine now =)
Throttle: ECUPin 38 and 56 = 0.5Volt
Vollgas: Pin 38 und 56 = 4.1Volt
No 4WD & A-LSD light, all fine =)
I bought some speedo LEDs , but I need better ones =(
But red light is looking really better I would say =)
Big boys can also have small toys^^
1st my AutoArt 1:18 BNR34 R-Tune in red
2nd my HPI 1:43 BNR34 Z-Tune in limited red/black edition
So, finally I hope you had merry christmas and wish you a happy new year 2013
Happy new year guys!
Here are my first news for 2013
This is engine bay before
and here the engine bay now, with my GReddy Suction Kit, but without my apexi filters because I need other adaptors
And also my toy collection is complete now =)
My Sky is getting famous^^
The story: We have done a photo shootig in year 2010 with a model. Now, two years later this model campaigns in the television show "The Bachelor"
This is the reason why she is in the bestselling newspaper called "BILD" now, with my car.
Here are the pics
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
