I have a problem with my BNR34 UK-Model with Link Ecu
I have no 4wd and A-LSD and the fail code 72 (TPS)
After I bought a new TPS I wanted to calibrate it and now the problem.
I can only calibrate it like in the BCNR33 manual (0,4 and 3,8 Volts on Pin38) but the BNR34 manual says I should calibrate to 0,5 and 4,2 Volts. But this isn`t possible at max I get 3,9 Volts or so and this dont fit at idle....
next problem, my mfd showes around 50% at full throttle. So I checked pin 56 and there I have 0,25 Volts at idle and 2,1 Volts at full throttle. but this should have 0,5 and 4,2 Volts or not?!
What is going wrong there?! =(
__________________
Good build thread man. 1 thing I didn't quite understand is why didn't you go for a reasonably sized single turbo setup instead? I had my last R34 GTR with -5's and now the R32 with -5's, both are laggy as f**k. And went in my friends R32 gtr with a single T04Z setup and 2.8L engine, the thing has lot more response! You did a full hearted engine rebuild so wouldn't it be better if you ditched the twin for a decent sized single turbo setup? That way you would have got more top end power with better response and less turbo lag. Just my personal opinion... :)
Edited by G0Z1LLAAAAA34
  • 1 month later...
After problems with my Link ECU and the AWD System I got my revised ECU back. Its all fine now =)
Throttle: ECUPin 38 and 56 = 0.5Volt
Vollgas: Pin 38 und 56 = 4.1Volt
No 4WD & A-LSD light, all fine =)
I bought some speedo LEDs , but I need better ones =(
But red light is looking really better I would say =)
Big boys can also have small toys^^
1st my AutoArt 1:18 BNR34 R-Tune in red
2nd my HPI 1:43 BNR34 Z-Tune in limited red/black edition
So, finally I hope you had merry christmas and wish you a happy new year 2013
Happy new year guys!
Here are my first news for 2013
This is engine bay before
and here the engine bay now, with my GReddy Suction Kit, but without my apexi filters because I need other adaptors
And also my toy collection is complete now =)
My Sky is getting famous^^
The story: We have done a photo shootig in year 2010 with a model. Now, two years later this model campaigns in the television show "The Bachelor"
This is the reason why she is in the bestselling newspaper called "BILD" now, with my car.
Here are the pics
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
