I have been in the process of upgrading the whole exhaust
removed the turbos and all the gear to replace the dump pipes,
Reassembled everything, then disconnected the battery to tack a few parts of the exhaust underneath the car with a TIG.
Now its all going, only thing changed is the exhaust(all of it), but the engine is running richer than ever before, like 13.0:1 @2000rpm in the shed, and as you back off to get closer to idle, it goes off the scales rich and obviously dies.>_<
Looked at AFM voltages, they are;
ENGINE NOT RUNNING
AFM-1 --- 0.44
AFM-2 --- 0.50
ENGINE @ 1500rpm
AFM-1 --- 1.60
AFM-2 --- 0.75
I removed the afm's cleaned them out and removed the cover from the top, checked the solder joins, they look good, they were new AFM's not long ago..
reassembled and checked again,
same results,
removed AFM's and swapped top one for bottom,
same results, and the voltages stay as is/similar.
I'll take a video and see if that helps too
any help appreciated
Edited by blue_vl_t
https://www.sau.com.au/forums/topic/383599-strange-mapping-problem/
Intake leak will cause the car to run rich as hell, you have measured air coming in and being given fuel for but lost before it gets to the engine. I forgot one tiny vacuum hose, it was enough to make my car idle with black smoke coming from the back. Check every single silicone connector, hose, seal, everything which helps the air stay in the intake.
Edited by SargeRX8
well i had looked a few times,
but i shoved some air in the intake this time and blocked the other, and what do you know, one air leak, i'll fix that, hopefully its all the problem is.
not sure why i always think a problem is something more complicated......
fixed the intake leak, but its running just as bad, like so bad i cant keep it running unless using 1500+rpm, took it for a drive around the block, stalled like 4 times, af mixtures are just going crazy, all over the place.
it will most likely be something simple, a matter of finding it....
ecu is PFC pro, z32 afm's
o2 sensors are removed and bunged up, also turned off on the PFC.
The wiring to the rear AFM is only just long enough to reach, so wouldn't reach the front one.
Im just making up some caps for where the afm connect to the pipework, see if there is anymore leaks, pressurize the system
Just pressurized the system with 5-10psi, looped the rocker cover breathers together, so it pressurized the whole motor, sump and all, its dead silent, no leaks, until the dipstick pops out, lol
so intake leaks, none.
I'll have to see about metering out the afm cables to the ECU, see what i come up with.
I recently had a similar problem with a Z32 that was meant to work..
I have a strange suspicion the body earth for that one is sensitive and may give a crazy effect... Mine was idling at 3.7v, yet i suspect the AFM will work fine when put into a known working case (will test tomorrow).
when using map tracer, in the shed, free revving the engine, if you hold the rpm at 2000rpm and gradually lift the throttle from the floor, the below lovely ms paint diagram shows approximately the path of the map tracer, ie which cells are being used.
Edited by blue_vl_t
blow off valves hooked up and working?
though you did pressurize the intake...
well, i haven't touched them, the car was running fine about a week ago, just removed exhaust side and reassemble with new exhaust.
as you said, pressurized intake, nothing was leaking......
Stock gtr BOV's
Edited by blue_vl_t
a prize.......
i'll take you for a spin, you live close by to Kalgoorlie, lol
I actually could not find anything wrong with the wiring, and i'm an electrician.
but the plugs on the r32/r33 model is quite crap in design, you have to push the plug in further the the bolt will pull it in.
but i recon it is was just a matter of unplug the ecu and plug it in, kinda thing. lol
I do think i will have to install another muffler, the 4" is kinda loud, i am only able to find the Magnaflow ones off the shelf, anyone know if they will do much, or someone to build one custom etc??
it should do, but my crappy superwizz turboteh bleed valve has a stripped thread, loose connection, which is probably why it was running more boost than i thought it was, i removed it, and its now running a massive 12psi, woo hoo.
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
