Have a bunch of R33 Parts leftlaying around
R33 GTR space saver $60
R33 GTST space saver $50
R33 Floor mats couple full sets $50 set and just front pair $25.00
R33 boot mat $30
R33 series 1 steering wheel crappy condition good for defects $20
R33 steering wheel with airbag again not best $50
R33 grille and badge $30
R33 front bar paint flaking slight hole on the inner section $70
R33 GTR rear spoiler insert new $30
R33 GTST aftermarket front pipe $70
R33 GTST std front pipes $30ea
R33 GTST std dump pipe $25
R33 STD springs $60 set of 4
R33 GTST 3 inch exhaust $100 centre muffler has split on join
R32 & R33 some engine pipes and mounts cylinder etc from $5
R33 centre console $35
R33 window reg in peices but was working $45
R33 GTST alternator $65
R33 GTST starter motor $65
R33 GTST air con compressor $65
R33 GTST oil filter housing has 2 outlets for relocation apparently $75
R33 overflow bottle $25
R33 cam covers x 2 $25ea
R33 washer bottle $20 2 pumps
R33 GTST standard exhaust good for defect rego etc $100
R34 standard exhaust good for defect rego etc $100
R33 GTST flywheel $50
Located in Sydney for pick up or can post
Must sell need space
Tks
Daniel.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
