  • Replies 50
Also selling my 888cc siemens injectors low impedance to suit gtr rb26 after $400 specs below
These injectors flow 86 lbs/hr at 43.5 PSI ( 3 BAR )
FEATURES:
  • Genuine, reliable Siemens Injectors
  • Excellent response characteristics
  • Robust Design
  • Low Impedance
Specifications:
  • Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
  • Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 86.2 lb/hr = 888 cc/min = 652.2 g/min
  • Connector: Bosch EV1
  • Spray Pattern: Pencil
Uploaded with ImageShack.us
Edited by ATLRGE
Hi mate i'm located on brisbanes southside near browns plains.
Un sure if they are z32 afm's but they looked bigger then my mates ones on his gtr so unsure. Unless you have part number for them i can check it out. They work fine only removed due to 15k of mod enhacements
Passenger side seat $150
Rb26 standard fuel rail $10
R26 mines pod adaptors running z32 afm's with blitz filters i think $150
R32 gtr dash board slight lifting. $150
R32 gtr lower steering column cover $30
R32 gtr Front passenger side gaurds $150
R32 gtr doors less switches and mirrors $120 each
R32 gtr boot interior lining rear over boot latch $30
R32 gtr boot lining pass side $30
R32 gtr front windscreen gutter tray no cracks $50
R32 gtr stock intercooled $100
R32 gtr centre console $80
R32 gtr gear surround plastic with 2 screw holes on pass side with no boot $50
R32 gloove box $60
R32 gtr driverside kick panel $20
R32 gtr plastic sill covers $30 each
R32 gtr interior light $20
Ame wheels to suit gtr with 215/45/17 tyres that are 80% tread $450
Hey mate pretty keen to come look at the boot interior panel and what ever else catches my eye lol.......when's a good time/day......I'm on the GC so guessing about a 45min trip up?
Hi mate,im looking for the drivers side plastic inner guard piece that covers the standard blow off valves,also the brake duct that bolts to it.Any luck?cheers Matt
Paid for one of the window rubbers and got sent the wrong side, contacted ATLRGE back and he said to keep it and will send the other one the next day express. That was over a week ago, have been constantly trying to contact him but no replys. BUYERS BEWARE!
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
