  • Replies 41
was thinkin bout this one...
Its supplied by electus distributions who are the wholesaler for most of Jaycar's products, they have a special right now for 3 CB radios,a nd I think this one was $25 or something... bargain price really....
maybe we should organise a group buy for before the cruise
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777004
Boyz If memory serves me correct those UHF are a POS! For $25 I can guarantee that yes it may cover the 5km range but It will break out alot and wont be clear...
acsplit arrange the group buy a while back as his work sells them... spend the $90 or so on one of his as they are quality.. I have one and have used the ones your looking at and there is a huge difference in quality
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777460
http://www.dansdata.com/digitalk.htm
and
http://www.strathfield.com/Product.asp?ProdID=201
Contacted Electus, turns out its the same CB but the older housing (ie its cosmetically out of style) hence why they're clearing em at $23... and for that price even if it only works for 500m its f**kin awesome.
Jaycar is still sellin em at $42
https://www.sau.com.au/forums/topic/38371-uhf-radio/#findComment-777547
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
    • Haha, that's so true. Minimal plans quickly turn into a full transformation, especially when you see what others are doing
