I have lots of left over wheels and semis left and now the car is gone no longer needed.
1. Pair of 90% Bridgestone RE55s 235/45/17s, still very soft and grippy, been in storage in cool and dark under deck storage $350
2. Pair of Falken 215/40/18 semi slicks good condition $100, again pics on request
3. Bronze Volk TE37 17 x 9.5 +35 and 17 x 8.5 +30 $2000 comes with second hand RE55s still good for at least another trackday or three. Paint is in great nick, no rash but may want to get new stickers.
No pics of these, they have been in storage, I didn't even get a chance to use these on my car. Can get pics on weeked for those who are serious. Looks similar to these
4. Set of 4 Toyo 888 semis 225/50/16 , 2 track days old on stock R33 gts-t wheels $600 (fast enough for a 1.09 at WP), at least another 4-5 trackdays in them, well above tread wear indicator.
5. Volk GT-N Forged dished wheels 18x8 + 31 and 18x9 +37 with 90% Conti Contactsports 2 265/35/18s on back and Yokos 235/40/18 on fronts $2000
PM or SMS me 0414610499
https://www.sau.com.au/forums/topic/383783-jap-wheels-semis-clearance/
you know u want to, and i will throw in an extra pair if front tyres, not that you have a shortage of tyres im sure lol
Haha, it's not the tyres I'm worried about... I would replace them with semi's anyway. It's losing a certain "appendage" when the missus finds out what I spent that much cash on.
I'm still considering it though ;)
  • 5 months later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
