FOR SALE
SET of NISMO LM GT2 rims in white... 18x10.5 + 15
all have 265 x 35 x18 tyres in good condition- sonar on front bout 50% tread- federals on rear 60-70% tread
all have centre caps and special aluminium tuner nuts and key in black.... $2500
**these are almost imposible to find these days and have that awesome oldschool look and stance
can try post pics or send via text/mms msg on 0404401766
ALSO set of TRUST/GREDDY type S coilovers to suit r33/34 gtr
these are height and 32 way damper adjustable- also have the damper extensions on the rear to poke thru parcel shelf (a must have) have both C spanners
good condition with no knocks or leaks $800
** willing to separate fronts n rears
2 x 33 gtr standard turbos... both suit rebuild $50 each
1 x r33 gtr stardard rear wing blade in kn6 blue/grey $50
1 x r33 gtr 3.5 inch kakimoto stainless exhaust.... 5 inch outlet.... will bolt up to 3 inch flange.... in awesome condition and sounds the part... can veiw on or off the car! $750
1 x HKS tuber timer... black in colour $50
*** can ship anywhere is aust at exspense of buyer
Can contact me on 0404401766 or via pm
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
