a small amount of rubber adhesive applied from the back should stop any blowby or mechanical sound the hole is creating. Fitting new rolls (surrounds) is a fairly easy job if you can purchase the correct part to suit.
Edited by madbung
https://www.sau.com.au/forums/topic/384019-speaker-repair/#findComment-6126164
Recently fixed both my original fronts with a tube of windscreen silicon I had lying around and 2 circles cut from some mouse pads. I was also conidering using an old rash top.
Quick Fix, may not be perfect but it worked. No more distortion and Zero $$$ spent.
I Loooove music but generally when driving, I'd rather hear the engine.
https://www.sau.com.au/forums/topic/384019-speaker-repair/#findComment-6126604
if its a sub , it needs to be perfect sealed off , or it will blow out again
I'd use 100% silicone, it drys and is flexible still some black RTV works as well.. if its not 100% it can rot , wont dry right, and most lilkely fall off. the real stuff smells like hell for a few days, so you might want the speaker left out for a few days to dry. or your car will stink.
some subs and good fronts/tweeters you can buy recone kits for, check parts express in usa as one source of repair kits
https://www.sau.com.au/forums/topic/384019-speaker-repair/#findComment-6127585
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
