swap it straightaway :thumbsup: . But you need a manifold, external wastegate and new oil lines. This can cost a lot of money but will be a fun r33 :cooldance
my friend has offered me a T40 turbo upgrade for a very little price.... for my gts25t stocky.... i'm not a turbo knowledge person so i am very unaware of doing it or not.
any help from people who know please pm me.
thanx
https://www.sau.com.au/forums/topic/38408-t40-turbo-upgrade/#findComment-777914
anyhow, getting right back on topic.
what type of t04?
is it a true t04 with the t04 flange?
or a t04 with the t3 flange?
you might not neet a manifold/wastegate or even lines depending on what the turbo is exactly.
PM me if you need help. A mate of mine works from home, just finished my car and he might be able to help you out in his spare time
https://www.sau.com.au/forums/topic/38408-t40-turbo-upgrade/#findComment-779427
Whats better for higher power figure a t04 with a t04 or t03 flange?
what type of t04?
https://www.sau.com.au/forums/topic/38408-t40-turbo-upgrade/#findComment-779637
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
