  • Replies 63
If you are using power fc and fc logit please send your data.
I can check data and if possible I will adjust then send back to you.
Do you have wide band AFR meter?
Im using x2 shops dyno and both mainline dyno but I can not tell same power or different power.
Yes,power is depends on dyno so 10-15kw different.
I think your RB did not install Bosch 044 size.
Or fuel module broken.
Fuel module is in boost right hand side and adjusting fuel pump voltage.
If this is broken , power only 10V so fuel will lean.
oh give up son.....
fuel pump doesn't make any difference to the power output, there was nothing wrong with the pump ecu, the pump was wired to a relay straight off the battery
Yes I have a wide band, it is sitting on the passenger seat of my soarer because I sold the skyline 12 months ago.
and NO, you will not be touching a single thing on any of my cars.
JESUS CHRIST!
oh give up son.....
JESUS CHRIST!
Fuel pump will make different injector duty.
lol
on my old R33 - when I went to a high flow I upgraded the injectors. the car made 225rwkw or something
I then went to a GT-RS with powerFC, z32, walbro pump and nismo 555cc injectors and made 255rwkw at unigroup engineering - Yavuz - who is well regarded here. he even suggest 555cc was on the lower side and I should have considered larger ones if I was going more boost etc.
at the track my duty cycle was 85% IIRC on that set up.
if i had standard injectors..well..wouldnt want to know...
fuel pressure reg upped pressure on standard injectors
nizmo Fuel Pressure Reg
Yeah by upping the rail pressure, this is dodgy and not recommended. By the time you buy a reg and rail you could have just got new injectors anyway....
Im using knock monitor k-mon and knock around 20.
Not on a mail tune you aren't, a mail tune for 250kw on stock injectors is playing with fire! Especially if you have to bump up the rail pressure, then you are completely guessing! this is a bad idea toshi!
Wut? The duty is completely controlled by the ecu.. the fuel pump might mean more fuel is injected at that duty cycle if the old one was failing, if it wasn't failing then it won't make any difference, that is the whole point of the regulator?
What exactly are we talking I need for Nistune though.
I been trying to read up about it and it sounds like a bit of a screw around.
Tell me if im missing anything.
Also do I lose any functions such as my aircon etc.
-Z32 ECU or R32 ECU (what motor from the R32?)
-Z32 AFM
-Some window switch (read about it but wouldnt have a clue why I need it lol)
-Nistune board (do I need software or is that only if i want to have it on my own laptop?)
Thanks guys
No more of a f**k around than any other ECU imo. Z32 afm will be needed for any turbo over 230-240ish kw unless you go a MAP based ecu like adaptronic, wolf etc.Being as you have R33 with VCT and the R33 ECU cannot be nistuned you need an R32 or Z32 ECU, the R32 one always works, I've read of a few issues with Z32, R32 ecu however can't control your VCT solenoid so you need a window switch. If you are going a big turbo I recommend a boost controller anyway, and the eboost street and eboost 2 both have a window switch built in. Window switch is about $100, boost controller is around $400
R32/Z32 ecu $100
nistune ~$400
Z32 AFM $300
Injectors $? depends what you go for anywhere from a few hundred to $700
Highflow turbo $700-1500 1
Clutch if you aren't running something tricked up already $1000
Tune $400-800
Total: ~$3700
or
full standalone ecu, 1000-1800 ish
Z32 AFM or window switch needed
Injectors
Turbo
Clutch
Tune
Total $4200+
You might think you can do it cheaper, but I can guarantee you you can't. You will almost certainly come into problems like air leaks, dodgy intercoolers that aren't good enough, broken studs, installation costs, more broken parts, diagnostic fee if you pay someone. Make sure you realise that this will be at least a 4000 upgrade once you factor in needed new tyres and all the other crap that comes with having lots of power
Edited by Rolls
That wasnt what I asked, what I asked was how much ignition timing did you have to pull out because of the lean spot at peak torque
Peak torque needs the most fuel as the engine is the most efficient, at 13.something :1 afr tells me straight away that you couldnt give the car anymore fuel.
I bet on a hot day it pings there every time unless there is bugger all timing
ye, but VG30s make peak at 6200,
Just had a look at some other graphs of VG30s, they do keep climbing a little after 4500rpm
this one, has a microguess and bigger injectors Edit - Tomei Reg
typical microtech fuel curve, but it makes another 60kws between 4000 and 6500
I send chip by mail order so Im telling to customer please go to dyno for check AFR and engine knock.
So dyno operator checking AFR and engine knock.
If engine will knock or AFR is too lean or rich I will send another chip.(some time talk to dyno operator)
I do not doing bigger injector mail order.
Im doing std injector only.
Also Im writing If you are not happy I will refund money.
If fuel pump change to bigger fuel pump , fuel pressure will bit come up (if do not adjust fuel pressure ) so fuel will rich side.
holy shit look at that AFR at peak torque, 13.2:1 !!?? it is 12:1 at the lowest the rest of the way, absolutely no safety margin there at all.
no thanks
I fixed AFR to 12.5 at around 4000rpm on dyno.
Customer up load sheet before fix AFR.
But yes , I adjusted AFR12.5 around 4000rpm and 6000rpm around 11.5-12.(also UNIQUE AFR 4000rpm 12.5)
He told me never go to race track so I think this AFR not problem.
I explained to him if you will go to race track I need adjust AFR to around 11.
Oh and how many times does a guy have to fork out 100 bucks for dyno time for each chip. Not to mention not bring able to drive the car.
Simply guessing the tune is a horrid way to do things
So it is 500 bucks for the chip + 100 dollars or more for a dyno check, tune is crap, send ecu back fit new chip, another 100 odd bucks on the dyno and repeat
If someone fits your chip and the motor blows up because it detonates itself to bits or melts piston crowns etc will you replace the motor?
True will he??
Of course not.
The whole point is why get a mail order tune when you can just pay for someone to dyno tune it properly with knock detection and wideband logging equipment. You won't save any money in the long run and you will end up with a 'guess' tune that is far from spot on.
12.5 AFR at peak torque in a country like Australia where we see 40c summers? 'I think' isn't really good enough when you have a two thousand dollars worth of engine to replace if it goes pop.
To the death dudes. Good to watch the dedication from the side line but me I'm over it now.
............... the winner will be anounced on the following page........................
Sometimes you have to beat a dead horse to get the point across.
Edited by Rolls
Who told you ????
Please give me my customer name.
Dyno operator check knock and AFR properly , engine never blow up .
Also I said if not happy I refund money.
Price is $400 for std turbo and dyno around $80-100.
Yes, around 3% need retune so some time dyno fee x2.
Power will get around 190-200kw AFR11-12 depend customer.
If he will go to race track I will tune to AFR 11.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
