r34 and r33 both have 370cc injectors, i had my r33 at 12 psi with the same turbo by the sounds of it (3071 with the vg30 rear housing)
i had much the same mods as you and it had 200rwkw at 12 psi and was still running rich, so 14 psi should be ok i'd think
I haven't heard of many people safely pushing more than 230kw with stock injectors, at 14psi hard to say as I don't know what turbo you have but you will probably be ok.
If you are running stock AFM you will be close to maxing that out as well.
I just assumed he was getting a retune... waste of time if you use stock ecu imo.
edit: nistune is next, the car will run like an absolute dog without a retune, get a 10psi spring and leave it at that, even 10psi will have it coughing and spluttering though with the bigger turbo.
Edited by Rolls
Id say the fuel pump would run out before the injectors.
If your tune is conservative then you will be running very close to maxxing them out..
My stock turbo on 10psi with Walbro pump maxxed out the injectors easily when it was tune with a Link G4.
It's kinda hard to say whether injectors should be fine or not without any specific info about the turbo. But my advice would be to get a package of Z32 AFM, injectors and fuel pump before bolting it all together. These three cost around 1000$ for a new AFM, a set of siemens 650cc's and a Deatschwerks pump.
Yea, highflows may be okay, may be not, depends on how the've been modified, but almost always they're worse that injectors that come from factory with a designed flow. There are some good inexpensive offers for R34 injectors, starting from 50$/inj or there abouts. Search, there are some details about injectors suitable for NEO posted by forum members Simon-S14 and I think urtwhistle.
Jecs used to be an in-house electronics manufacturer for Nissan, e.g. my AFM has "made by Jecs" badge on it, so it might be a highflowed set of stockies.
Do you have a link to the said set of injectors?
Edited by Legionnaire
simon uses siemen deka injectors, the 3/4 length 60lb injectors are a direct fit but will just need to rewire new plugs. you can get this from the states the cheapest.
im runing 600cc high flows and havent had any fuel or tune issues. currently making 245rwkw and soon to be 300.
speak to PJ on this forum, i got them down thru him.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
