  • Replies 5.5k
Posted Images
Got a good feeling about Mark this year,maybe its his time?
I definitely think he has the raw speed. Consistency? Probably not but i hope to hell I'm wrong.. Unlikely he will get clean racing with biebs likely to take priority again.
you guise seen this?
http://predictor.aut...ampaign=30bonus
this is the interesting bit.
http://predictor.autosport.com/prizes
it's not open to us atm. :(
i think.
That is the most awesome prize planet earth will ever encounter.
EDIT: Actually, winning anything more then twenty thousand pounds would be better.
The news that shooting has started on the Lauda/Hunt film Rush has been greeted with great anticipation in the world of F1. Buoyed by the success of the Senna movie investors have
put their money into the tale of two strong-willed individuals pitted in one of the most climactic seasons of racing, 1976.
http://www.planetf1.com/editorial/7545946/F1-Goes-To-The-Movies
^^ it's a long read.
Shannons is offering you the opportunity to win a 5-day tour for 2 people to the world's most popular Grand Prix - the 2012 Monaco Formula 1 gp.
http://www.shannons.com.au/monaco
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
