Where is the f1 site timing?
Only has top 3 with no times :S
All the times come up for me?
Timing is here:
http://www.formula1.com/live_timing/live_timing.html
Or Here:
http://www.planetsport.com/live/f1/
  • Replies 5.5k
Posted Images
It's Practice - realistically means nothing. Plus half of P1 was wet.
After being in the Pits for a few hours today and watching the cars there is only one clear distinction so far.
The McLaren's look totally different to any other car out there today.
The nose cone and front section/aero is nothing like the rest of the field. It'll be interesting to see what occurs on race day. Is it an advantage or will the simply fall away?
Most other cars nose-cone & front end wise are reasonably similar.
^agreed if the Mclaren's have a good couple of good first races i think they and (button) will be hard to beat.
hope we might see tears from vetool;
http://en.espnf1.com/australia/motorsport/story/73105.html
All of us real F1 fans knew that quite some time ago Ash, but thanks for the corporate breaking news ;)
Anytime :thumbsup:
The other cars today appeared to have more corner speed compared to the McLarens @ T1
However the McLarens were on the pedal a lot earlier out of the corner.
Bet you didn't hear that in the pre-season internet jibber jabber.
even more promising is the combination of no-blo diffusers and tougher deflection testing of aero elements may have truly ended RBR's domination :happy:
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
