  • Replies 5.5k
Posted Images
Damn team played him twice. No pit and wrecked his flow on the radio.
Aren't those team-radio feeds like 1-2 laps behind the present though?
Or have they got them more up to date now?
So whilst it looked like he basically went off a few corners later, it actually wasn't the case.
Which would also mean he was ignoring those orders are until then he was still gaining!
Why is it that Marks car is the slowest in a straight line out of the front runners.Even with th DRS he still couldnt pass and had to do it on a different part of the circuit whereas finger boys just flew past???
Sauber weren't telling him not to pass, they were just telling him to do it without making contact and losing 18 points.
Probably shouldn't have done it, but I doubt it changed the way he was driving anyway.
And yeah they're delayed so it wasn't just before he made the error. It was a tiny error but costly in the conditions...
Great to see a mixed podium and a good win for Alonso. What's Hamo's go anyway he should stop saying all the "right" things and just speak his mind
his expressions and body language say it pretty well anyway. Good to see a result for Perez, Kimi and Senna as well.
Also when was the last time there was no Red Bull on the podium?
Edited by NISMATT
Few pages for just this one race.
At least 5 pages per race including practice/quali/general shit. 20 races.
200 pages by the end of season?
But yes, very good to see a mix on the podium and midfield.
Makes the castrol prediction very difficult.
I tried using previous race results for this one along with last years results(sort of). Didn't really help. Maybe cause of the rain, but we will see in China.
Strange that of the top three teams, none showed any real pace today, at all. Possibly a set up explanation
Perez with almost the drive of the day today. His team left him out far too long, and his off was a suspiciously well timed
Disappointed we didnt get more of a fight at the front for podium spots. Was more or less settled at the restart
GREAT midpack action, Senna with the mad skills
Not sure if the radio is delayed now, the radio channels are open this season for all to hear.
SV post race
hmmm
http://en.espnf1.com/malaysia/motorsport/story/74313.html
http://en.espnf1.com/f1/motorsport/story/74343.html
bit of a harsh penalty i think but HRT should take him out every race, worth a 20sec penalty for us to loose the tool
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
