  • Replies 5.5k
Posted Images
when we go to the ten broadcast, we'll see the race live but qualifying will most likely delayed.
bahrain quali starts midnight on saturday night/sunday morning. so most likely live. i'd say that quali will still be live for more prime time races too. may be proved wrong in the future though.
Bahrain is going live on one hd. When is the swap?
Who will shine in this race? Seems petronas should do well in qauli with there ducts/drs on all 3 straits
my tv guide shows channel 10 as the one playing bahrain
Ferrari total 37
Nando 37
Massa 0... :ermm:
what gets better is that he averages a quali result of 13th
but finishes an average of 15th
so its not like he's just having s bad quali and making up for it, he actually going backwards so far
this guy is so gone in 2013 i would bet my house
since it'll be 10 digital, it should still be HD, yeah?
but if he wins the championship somehow...
:rofl:
http://www.yourtv.com.au/guide/sun/
and shaun, doubt it will be in HD. don't think they broadcast any channel other than oneHD in hd, otherwise SD only set top boxes wouldn't be able to show the program
EDIT: dezz got in just before me
Somthing similar could be said about schumi
except that before the last race, it was only Schumi who had scored points for Merc this year. And had consistently outqualified Nico in the first 2 races. Even with Nico's freak pole at his favourite track, Schuey is still leading him in the qualifying comparison, averaging 3rd whereas Nico averages 5th.
And until this race it was Schuey who gave Merc both its best grid position and race result over the last 2 years.
So exactly like Massa, except in every possible way...
yes, the Schu v2.0 continues to suck on Sundays
yeah, Schuey sucks by having a gearbox fail after a handful of laps in the first race of the season, being punted on lap 1 by Grosjean who had NFI what was going on, and having a wheel not tightened in a pit stop. Man Schuey sucks...
Edited by hrd-hr30
Lol spot on, saved me a post
Talk about taking things out of context guy.
let me replay it for you... emphasis mine.
I hope it does
Will more than likely push ferrari further down the WCC order with their distict (sic) lack of point scoring ability
and hip-hip-horay for that
Ferrari total 37
Nando 37
Massa 0... :ermm:
Somthing (sic) similar could be said about schumi
So I guess good news for webber in that he was mores comfortable with this layout than the first.
And lol at helmuts comments about webs.
"Red Bull will continue to develop the exhaust system used on Mark Webber's car at the Chinese Grand Prix despite Sebastian Vettel's preference for a different design.
After the Chinese Grand Prix, Vettel said: "It was an interesting weekend, we collected a lot of data on different cars but ended up more or less in the same place [fourth and fifth], which was pretty funny. I think both packages have their advantages but for next week we will see what we do."
Red Bull advisor Dr Helmut Marko told Servus TV on Tuesday: "We will go on with the Mark Webber car."
As for why Webber feels more comfortable in the updated car, Marko added: "Mark is less sensitive to the [car's] behaviour. He just needs four wheels, but it's different for Vettel."
