  • Replies 5.5k
Posted Images
webber on good form with 17 "umm" "err" in what? a minute?
Maybe he needs to have a brain injury like Molly Meldrum to cure himself??
Still cheering the Chin on from the clean side of the track. Hook it up, fake to the inside and drive it around the outside of the Biebster into the first turn.
Daniel Ricciardo says he got "better and better" in each session as he worked his way to a career-high P6 grid slot for Sunday's Bahrain GP.
While his team-mate Jean-Eric Vergne struggled on the other end of the timesheets, Ricciardo demonstrated his talent around the 5.412 km-long Sakhir circuit.
Breaking into Q3 - for the second time in four races - Ricciardo impressed as he clocked a 1:32.912, which put him less than half a second behind pole-sitter Sebastian Vettel.
"It feels very good and I am very happy with that result," said Ricciardo.
"We had a below average week in China with some updates we brought. We persisted with them and we made them work significantly better here, which is down to the hard work of the whole team.
"My communication with the team was also very good and it has helped us get into Q3. I was happy with my driving and I got better and better in each of the sessions. It's not always you have a day like this, so I can enjoy the moment, bearing in mind that it's tomorrow that counts."
He added: "Now we have to put it all together for the race and tonight we will be looking at all our strategy options regarding tyres.
"It helps to go into a race feeling confidence and starting from sixth, I have to focus on scoring as many points as possible, as this is the best chance we have had so far. I hope I am still smiling tomorrow evening."
Meanwhile, Vergne, who qualified P19, is under investigation for ignore the red light at the weighbridge.
http://www.planetf1.com/driver/18227/7689634/Ricciardo-very-happy-with-qualy
what a nice guy.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
