  • Replies 5.5k
Posted Images
yay for kobayashi. :banana:
Pos Driver Car Time Gap
1. Jenson Button McLaren-Mercedes 1m47.573s
2. Kamui Kobayashi Sauber-Ferrari 1m47.871s + 0.298s
3. Pastor Maldonado Williams-Renault 1m47.893s + 0.320s
4. Kimi Raikkonen Lotus-Renault 1m48.205s + 0.632s
5. Sergio Perez Sauber-Ferrari 1m48.219s + 0.646s
6. Fernando Alonso Ferrari 1m48.313s + 0.740s
7. Mark Webber Red Bull-Renault 1m48.392s + 0.819s***
8. Lewis Hamilton McLaren-Mercedes 1m48.394s + 0.821s
9. Romain Grosjean Lotus-Renault 1m48.538s + 0.965s
10. Paul di Resta Force India-Mercedes 1m48.890s + 1.317s
Q2 cut-off time: 1m48.993s Gap *
11. Sebastian Vettel Red Bull-Renault 1m49.722s + 0.472s
12. Nico Hulkenberg Force India-Mercedes 1m49.362s + 0.112s
13. Michael Schumacher Mercedes 1m49.742s + 0.492s
14. Felipe Massa Ferrari 1m49.588s + 0.338s
15. Jean-Eric Vergne Toro Rosso-Ferrari 1m49.763s + 0.513s
16. Daniel Ricciardo Toro Rosso-Ferrari 1m49.572s + 0.322s
17. Bruno Senna Williams-Renault 1m49.958s + 0.708s
Q1 cut-off time: 1m50.126s Gap **
18. Nico Rosberg Mercedes 1m50.181s + 1.188s***
19. Heikki Kovalainen Caterham-Renault 1m51.739s + 2.746s
20. Vitaly Petrov Caterham-Renault 1m51.967s + 2.974s
21. Timo Glock Marussia-Cosworth 1m52.336s + 3.343s
22. Pedro de la Rosa HRT-Cosworth 1m53.030s + 4.037s
23. Charles Pic Marussia-Cosworth 1m53.493s + 4.500s
24. Narain Karthikeyan HRT-Cosworth 1m54.989s + 5.996s
http://www.autosport...t.php/id/102121
3 place penalty for pasta
right next to lewis
ohhhh no
AHAHAH love it! should be a good start ;-)
On a different note, WTF will happen with Ricciardo? does anyone know if he will be re-signed? i know its his 1st year and all but would they be annoyed that their last two drivers were at least finishing near or in top 10 and the 2 newies are nowhere near it?
I want him to be the next Webber but will RedBull allow for a long amount of time for him to adapt?
His first race was a good one, then in went down hill.
in the last 30 mins on fox sports live streaming there has been:
Discussion from Horner
Interview with Hamo
Race track analysis
Discussion from previous F1 greats
F1 Qualification review
right now, interview with Chin on the straight
...now to ch10
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
