  • Replies 5.5k
Posted Images
Will be interesting to see what gear ratios the teams choose for monza next wee, given how last year in the drs zone the mercs were walking past the teams with shorter ratios. I doubt we will see redbull near the front next week
good job on ruining it for everybody, rook
and why is there no investigation into his obvious crowding of Lewis to the edge of the track (even though he moved again after Lewis moved over for him)
fkn gyp
