p2 Times
01 Sebastian Vettel Red Bull 1:37.718 17 laps
02 Mark Webber Red Bull 1:38.475 0.757 36 laps
03 Fernando Alonso Ferrari 1:38.483 0.765 35 laps
04 Lewis Hamilton McLaren 1:38.748 1.030 31 laps
05 Jenson Button McLaren 1:38.786 1.068 32 laps
06 Felipe Massa Ferrari 1:39.029 1.311 33 laps
07 Nico Rosberg Mercedes 1:39.448 1.730 32 laps
08 Bruno Senna Williams 1:39.531 1.813 38 laps
09 Kamui Kobayashi Sauber 1:39.653 1.935 36 laps
10 Michael Schumacher Mercedes 1:40.115 2.397 30 laps
11 Kimi Raikkonen Lotus 1:40.166 2.448 32 laps
12 Pastor Maldonado Williams 1:40.230 2.512 35 laps
13 Romain Grosjean Lotus 1:40.286 2.568 32 laps
14 Sergio Perez Sauber 1:40.326 2.608 35 laps
15 Daniel Ricciardo Toro Rosso 1:40.435 2.717 30 laps
16 Jean-Eric Vergne Toro Rosso 1:40.516 2.798 32 laps
17 Nico Hulkenberg Force India 1:40.700 2.982 34 laps
18 Paul di Resta Force India 1:41.430 3.712 35 laps
19 Heikki Kovalainen Caterham 1:42.476 4.758 38 laps
20 Timo Glock Marussia 1:42.652 4.934 33 laps
21 Vitaly Petrov Caterham 1:42.846 5.128 38 laps
22 Charles Pic Marussia 1:43.538 5.820 38 laps
23 Pedro de la Rosa HRT 1:44.453 6.735 16 laps
24 Narain Karthikeyan HRT 1:45.114 7.396 20 laps
http://www.planetf1.com/driver/3213/8253198/Prac-Two-Two-from-two-for-Vettel
  • Replies 5.5k
Posted Images
the old aero packages generated too much downforce, and the FIA periodically has to fiddle with the allowable wing dimensions to keep cornering speeds reasonable
*waits for some retard to say driver and spectator deaths are a perfectly acceptable trade off for 'spectacle'*
yer coz tyres that delaminate is so much more ''safer''................. :rolleyes:
Having tyres that delaminate is safer than having higher speeds. One is only a drama at the end of the tyres life, the other means that if something goes wrong at a higher speed, there is more chance of injury or death.
Ferrari pushing the rules to the limit and deliberately getting Massa a grid penalty to move Alonso up another spot. Clever, but if it was Red Bull doing that everyone would be spitting chips calling them cheats
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
