They are running the Mountain Straight Hillclimb - this is a yes, yes , yes - Tim in the Gould last weekend took nearly 2 seconds off the current record in 37' s at a clubbie -congrats to Tim and family
Please do not tell HRD30 that a 300K car ran, contested and won a club day in preparation for an Aussie - also don't let him K got second outright for sv class for the weeknd in her road rego'd R32 against a big field and heaven forbid - Stuart got 2nd to an evo on Saturday in Sports Sedans againts Lachlan and Stephen's Evo - Excellent / result for effort and at there own choice running sports sedan class and thanks for slowing down Sunday to give me 2nd outright for the weekend - congrats to Doug - Lola - 4500 for winning the weekend overall. Bugger me the best thing is for fact none run a huge budget and the best is the crew is family ages vary about 14 months to plus my dad 76
Great weekend had by all - just ask the competitors, and spectators alike!!
See you at the Aussie
Cheers Stuart and Karen
https://www.sau.com.au/forums/topic/384437-2012-nsw-aussie-hillblimb-preps/
as I said in the other thread, hillclimbs are different. They've always been about the F.Libre open wheelers and its great seeing a bunch of them going head to head on a level playing field.
how many people got 2nd outright??? "K got second outright... to give me 2nd outright for the weekend..."
2nd outright is different from 2nd in class. hth
Thats great news Stu,,,2012 for me will be back to Hillclimbs in the Radical and some in the Skyline.
Nice vid by the way tiger.,,,good to see that mega buck taxi of yours behaving herself.
Cheers
Neil.
  • 3 weeks later...
Cheers
Neil.
Bout time for you to get back to the track - and my mega buck taxi was on its last outing for us as a couple to prove itself - lol (I thought the skyline was a pain in the credit card) Don't get a used taxi!!
Our plan - I will be running the taxi in Sports Sedan and you and Karen can share the skyline battle and hopefully with a few others from SAU?
PS SAU Merry Xmas and Happy New Year
Cheers :cheers:
What areas of the Falcon chew the money? Curious, as I woudl have thought they would be reasonably economical to run given their turn of speed
Hi Roy
3000km engine service must replace roller lifters, valve springs and retainers - basic head service costs around $4,500 - $5K
At the same time, set of brake rotors and pads - $4,500
Gearbox service and re-race diff also at 3000km's - $1500
6000km service is all of above plus set of pistons, rod bolts, stud kits, gaskets etc - $5k
When required AP carbon clutch - $11K, dry sump pump, crack testing -spindles etc, new wheel nuts every twelve months, along with in tank lift pumps. Every two years recharge fire bomb, replace all wheel bearings.
Thats the basics anyway Roy
Cheers
i'll just stick with the hairdresser fag mobile for cost wise!! haha
Id love to give hill climbing a crack next year. done mountain straight hill climb back on 08 and loved it!! just wonder how my gay car would go in its class
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
