  • Replies 75
Posted Images
I have 12 degress on intake and 10 on exh, and with stock cams and stock turbos the R32 makes 292rwkw @ 19 psi, the 34 has 10 degress intake and 4 exh with poncams and -7s made 310rwkw, so 8 in and 4 exh i doubt thats going to cause the problem.
I'd be looking at the intake pipes for a leak or crack, check all hose clamps are on right and tight, check the BOVs bolts are done up tight, even go around the plenum with a can of brake clean with engine running and see if idle changes at all to see if a gasket has given way or a small hose hasn't come off.
6/7 kw is a sizable loss but not what your looking at as the problem but something I'd be looking at improving
Take out air filter and stick a screw driver handle in the airbox to hold it open and see if that helps
them mayby look at different dump pipes as x-force are an upgrade to only the stock 32/33 stuff but only just and are not the best, I picked up 20kw (290 awkw to 310rwkw) from changing from HKS dump pipe to the CES Comp Series dumps and front pipes, I hate knocking stuff so this is really only a suggestion
Thanks for the post. I didn't know you could run that much boost with stock R32 turbos. I'd say DVS JEZ will go through those things providing the compression test comes back ok to start with. Also... could leaking piping be the issue if its still making 17 p.s.i which I'm guessing is read at the inlet manifold? Which is after all the piping, cooler etc?
And as far as I know the xforce dump pipes are an exact copy of the hks ones (split type) that surely should be sufficient enough for 300+kw?
from what ive read and from before/after dyno graphs i dont think that the dumps would be the issue
they would be 100% fine for 300kw and lots more
XKLABA i dare say that ur 20kw gain would have mostly been from ur front pipe change, there are large gains had from changing to bigger diameter front pipes
you can run that boost for short spurts, dyno and drags but not burnouts or track events and have done so for 8 years now with two sets of turbos, first set had to be changed cause the bearing where gone with 4mm + shaft play and no damage to either wheels.
yeah comp test is a good start but if it isn't given a slight wiff of blue smoke from exhaust then i'd say comp would be good, a small but consistent leak would be over come with the boost controller making the boost level, also check there isn.t a leak around the exhaust manifold before the turbos, even a small leak will rob power.
Joe, the design of the dump pipe can make a big difference ( bigger then front pipes ) in both responce and power and if you get to see the CES comp series pipes in real life you can see way they work so well, I've tried a few styles on both the 32 and 34 and i have CES on both now, the normal ones on the 32 with equal lenght front pipe and the longer comp ones on the 34
I remember reading a thread in this forum where some had a mildly modded gtr (around 300rwkw)
they performed a before and after test using stock dumps and then some after market larger dumps
the difference ended up being 3 fifths of f#ck all
not sayin ur wrong but at these sorta power figures i dont think the dumps make that much difference,
not doubting that CES arent a better dump either, i just dont think the dumps are his power problem
ill see if i can find the thread
As data point, I'm running xforce split dumps with -7s on 17psi and making 305kw. Factory air box. Another reason not to focus on the dumps at this stage is that changing them is a big job, so you only want to consider it if you have very strong indications that they are the problem. So, IMO, forget the dumps for the moment.
What are your front pipe dimensions? FWIW the primaries on mine are 56mm ID and the secondary is 76mm.
Other than front pipe, I'd be looking at your inlet side for leaks or restrictions.
What spark plugs are you running and what gap? I had an issue with mine when I first got it Dyno tuned, ended up having something like 0.6mm spark gap
Had spark blow out and wen we turned the boost up more it didn't gain any extra power
To be safe I changed my coilpacks and coilpack wiring loom too
MrStabby - front pipe is exactly the same dimensions as yours.
SiR RB - I'm not sure what the gap is as I left that all to the tuner but I know the plugs are just the ngk cheaper ones
I have faith in DVS JEZ to get to the bottom of this Jon
Checked the front of the exhaust cam for wear? how is the ignition timing be set? don't use the loop at the back of the motor, get a plug lead and shove it up coil #1, then run the light off that, with the TPS unplugged.
Edited by iplen
This means get a timing light, remove No 1 coil get a old school lead for twim cam cut it in half stick one end on the spark plug and the other end in the coil and read the timing light off the lead, we on the other hand just open the timing light reader and hold it against the front of the coil with it still in place, to check if you base timing is correct.
+ 1 on comp results
as for the dump pipes, it was a suggestion for something to check as a possibility, coming from things i have exprienced in the near 10 years i have been playing with these cars and was something I reseached heaps in the path of getting the 32 as fast as it is.
The front pipes on 34 where the HKS ones with a 76mm in and 80mm out equal length, I don't think there was 20kw from changing them.
Just trying to help
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
