Hey guys bought some coilovers and put them in last night, as the thread says they are BC Coilovers. Now the front will go lower and sit how i want them to but the rear, but the rears, they do not go as a low as i am wanting... I have never really worked with something like that setup before, the strut and then the rear spring. now with the strut i raised that to as high as it can go, (to make it lower) and then the spring i put i all the way down to it lowest point to make it lower, am i doing this correctly? what do i need to do because i am running 18's on it and it still showing around 25mm off the tyre? I do not want to slam it down all the time, but i just wanted to lower it. I am thinking of going to get a new spring made up from Adelaide, or let me know if i am doing something wrong?
Just wondering because the fronts can go sooooo much lower, but the rear is still pretty high??
Let me know..
https://www.sau.com.au/forums/topic/384766-stagea-bc-coilovers/
you need to shorten the strut and lower the spring at the same time. dont lower the spring too much as it needs to remain captive in the seat at full droop, so it doesnt pop out when you go over a big hole.
From the middle of the wheel, to the guard its 370mm, seems as low as it can go, the front can go so much lower, and i was just wondering why or how i can get the rear lower, you will see in the picture below that i only wanted to lower it like 10-15mm all around, just to sit it down on the rim a little better.
Edited by purezx
Purezx; they should go much lower than that; mine are at 355mm with plenty more thread to go.
I reckon I could get another inch easily.
Hell, look at Jays;382078_10150382772448024_785208023_8373296_1685795364_n.jpg
Have you got some pics of the spring and adjustable perch mounted in position? Not saying you've done it wrong; but something might not be quite right and a photo might show us.:thumbsup:
Have you loosened all of your arm to chassis mounting bolts (pivot points on the subframe) to ensure they aren't bound up? You need to get it on some ramps, so the car is loading the suspension then loosen; maybe even pry open slightly, then retighten all of the lower mounts.
Edit; lol Jase; great minds and all that...:nyaanyaa:
Edited by Daleo
The little wheels wont be helping matters.
lol, they're 18's. Just smaller tires from what I can read. Some 245/45's will fill the guards a bit more. Dale might suggest 245/50's to do the job, but I'd disagree.
General consensus is 245/45 is the best choice for guys running 18's. It's a popular enough size to be affordable. I wouldn't go smaller than that, and was actually thinking of going to 245/50, until Dale talked me out of it. That size has a diameter 77mm bigger, so will really fill those huge guards, but looks could be compromised.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
