Just after peoples opinions on this.
I was out driving yesterday and about 1/2 hour into the trip I tried to acellerate up a hill and noticed I had bugger all power.
It feels like I have 1/3 or less the power that I normally have, it takes over 5 seconds to acellerate from 90 to 100 :blink:
I didnt hear or feel anything happen, the motor still runs and idles smoothly but has bugger all power.
The boost guages (factory and eBoost) both show vaccume but neither will rise above zero when under load.
When the load / revs is in the area where it would normally produce boost it emits some white smoke. I guess this is cause its now running quite rich without the extra air?
So my questions are, what can I look for that may indicate what the problem is? Does a blown turbo exhibit these symptoms?
Could it be something else like the eBoost?
Some basics
- RB34 GT-T
- FMIC
- PowerFC
- eBoost
https://www.sau.com.au/forums/topic/384961-so-something-broke/
Pull the dump off and have a look at you turbine if there is one. Like mafia said check cooler piping. Don't drive it untill you find the problem if it is a blown turbo there will be bits of ceramic everywhere if some gets into the motor then hello rebuild. Also is it a rb34 strocker or did you mean r34? Guessing it's a rb25 neo. If it is the turbo then pull it all off including manifold and ensure it's all clean also drop the cat as it will be full of turbine wheel. When my turbo blew made hardly any noise if you have a loud exhaust you wont hear it.
Check list
Check for split /popped silicone hoses
Remove dump check turbo turbine wheel if gone remove turbo and manifold also cat converter
If its neither of these drop the cat it may be blocked and will cause little or no boost
These are my experiences in the past they may help otherwise I'm not sure
If there is one. had to laugh at that.
Will do that when I have some time on the weekend.
Had already had a look at the plumbing, could not see anything obvious.
Ouch.
I have already driven it over 300km (problem happend far from home).
If the impeller breaks up can it actually make its way past the the FMIC? I would have thought it would have got stuck there?
Doh!!!
Yes its a R34 with a RB25. Silly slip there.
Check list
Thanks, will run through the rest of these over the weekend.
There is a bearing case that stop it getting anywhere near the cooler haha. It can go back up the manifold and slip into the engine when the valve is opened 9 times out of 10 it won't but still that chance. Also your want to look at the rear housing of the turbo that's the turbine wheel that's the one that will go more then likely if it's not that wheel check the front but I doubt it. By memory its a 6 bolt flange on the dump 4 bolts 2 nuts I think it's a 13 mm spanner bit of a pain to undo but not impossible. Feel free to ask questions if you get stuck
What exhaust system do you have mate?
If you cant see anything wrong with the turbines, id say that a resinator has collapsed and blocked the exhaust.........or somebody doesnt like you blocked it :rolleyes:
The symptoms you just gave sound exactly like mine when mine collapsed, apparently its common with kakimoto exhausts.
Just drop the exhaust at the downpipe and drive it down the road, you will soon see if it has solved your problems :thumbsup:
Ahh that sucks mate (not as much as P-platers writing your car off though). I was running a highflow on the Neo engine in my Stagea, built by a local turbo guru but even something like a Hypergear bolt-on highflow (not one of their huge ones with custom housings) would be an excellent bang-for-buck upgrade. Should be able to get an easy 220-240rwkw out of the standard injectors, was only running 15psi through mine but it certainly made the 2t bus get up and boogy.
In the end Ive decided to send by old turbo to hypergear to be rebuilt and highflowed.
Seems to be the easiest and most cost effective option given that I dont want to change injecters, AFM, etc.
Super happy fun sideways time will shortly ensue! :devil:
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
