95GTST - "From what did u form that premise?"
Ther are no problems with it working in a 33gtst..
I have upgraded to a full management computer, which has its own boost settings, and will be driving full boost everyday. Without the need for the Profec it wuld be nice to compensate for some costs.
Thnks
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
