I have come to a very well thought threw decision to re home my pride and joy GTR. I searched high and low Australia wide for this amazing example of the famous GTR and I have no doubt it is one of the best if not the best in Tasmania with out sounding anal this car is a must see.
I would like to note this car is an expression on interest only sale at this stage as I am not letting it go until early February and I will only sell for the right price.
The car has had a lot of rubbers, door trims etc replaced in the 2004 rebuild in Japan and feels like a new car, no squeeks or rattles at all.
Having owned a few GTRs through the years this is without a doubt, by far the best build and performing GTR I have had, hence not too fussed if it sells.
The car was originally gunmetal grey before the owner of it then in Japan did a ground up rebuild of the car in 2004. It was resprayed a metallic factory color wine red but with lots of pearl and the engine bay was sprayed a stark white, maybe to show off the engine or to show up leaks and issues a lot easier.
This chap worked at Nissan in Japan and so had access to many new parts for the GTR and is why you'll find a lot of the seals and small plastic parts are like new as well as a lot of engine bay components.
Basically from there he dropped in the new motor and turbos with most of the listed supporting mods, the only mods added in Australia were the injectors, adjustable cam gears and the boost gauge.
A bloke well known in the NDSOC (Nissan Datsun Sports Owner Club) association imported it for himself in 2005 and owned it for a little over a year, taking it to a few show n shines and concourse events.
I have always kept it garaged and drive it on the very rare occasion and only on a clear and dry day.
Fastidiously maintained, never parked at shopping centres or with general cars as it has not one dent.
Oil services have always been done every 5,000kms, quite often less and always with a new filter.
Only 2,500kms ago I changed ALL fluids, gear box, front and rear diffs, engine oil + new oil filter and fuel filter. Also flushed the radiator and refilled with coolant.
While I have owned it I installed kill switches, relocated the battery to the boot and installed a quality custom catch can with braided hosing and speed flow fittings. Completely stripped the hicas and installed a hicas lock bar for improved handling. Installed a 2wd / AWD switch, I also purchased a professionally polished plenum and highly polished engine covers (Looks amazing, all appropriated gaskets and seals were replaced also).
Modification list below:
:: Engine ::
- Brand NEW R33 RB26DETT N1 Engine, only done 50,000kms
- Brand NEW R34 N1 Twin Turbos, same mileage as new engine
- Greddy adjustable Cam Gears
- Sard 800cc Injectors
- HKS Drag Intercooler (600x300x100mm tube & fin design) 3" Inlet / Outlet
- Custom 3" Intercooler Piping
- Custom 3.5" mandrel Exhaust System from turbos to 4.5" rear muffler - Amazingly subdued off boost but sounds great on full boost, very angry and tough. System is quiet easy on the ears as well with zero drone.
- Oil cooler with air guide and remote oil filter for easy replacement
- Custom Catch Can, braided hosing and speedflow fittings
- Twin Apexi Pod Filters
- Apexi Power FC ECU (tuned by Ben @ Racepace VIC on 20psi = 322awkw )
:: Drive Train / Brakes ::
- Hicas totally stipped, NEW hicas lock bar fitted
- Jim Berry Full Monty single plate carbonetic clutch, 3600lbs pressure plate matched to an R31 Fly Wheel, beautiful clutch, never had it slip on me once with current power level and operates almost like a standard clutch in terms of pedal heaviness and drive ability in traffic.
- VSpec 2 Brembo front calipers with Lockheed rotors and pads, standard rear calipers and rotors / pads, pulls up exceptionally well, feels like your eyeballs will pop out and its still got more in it before the ABS even kicks in!
- Teflon braided brake lines
:: Suspension / Bracing / Wheels ::
- Tein Coilovers, adjustable stiffness and dampening
- 11 structural bracing bars:
--- 2 Front & Rear Strut Braces
--- 1 Interior Cabin Brace (per image)
--- 4 Front & Rear Guard Braces (1 under each guard running lengthwise)
--- 1 Brace underneath near rear of engine / front of gearbox
--- 1 Mid trans tunnel Brace connecting either side of the tunnel
--- 2 Rear subframe Braces (1 each side)
- Volk Racing CE28N 17 x 9 Forged Monoblock lightweight Wheels (includes VR Duraluminium wheel nuts and VR valve caps) This combination of stiffness and grip makes for a very flat and stable cornering attitude with great response from the tyres under braking, cornering and acceleration.
- 90% tread on tires all round 255 width
:: Exterior / Interior ::
- Lightweight fibreglass bonnet
- Aerocatch Bonnet Pins (lockable)
- N1 Side Skirts & Vents in front bar
- Momo Race Steering Wheel
- GTR carbon fibre Gear Knob
- Apexi EL2 Mechanical Boost Gauge
- Nismo 320kmph Speedometer
- Kenwood CD / MP3 head unit with what looks like standard speakers front & back - Fire extinguisher mounted to rear cabin brace
- Original Nissan GTR floor mats front & back with the original flare case in the front passengers foot well
- Original Nissan GTR front & rear seats in excellent, nearly as new condition - bolsters still all firm & solid, top of rear seats are not faded like nearly all other R32s are.
- All dash & trim in excellent condition with all accessories, gauges & lights fully functional - heater & aircon work as good as the day it rolled off the factory floor.
This car would suit even the fussiest buyer, this GTR is almost faultless.
Nil oil leaks.
6mths Tasmanian Registration just paid for.
Car is currently in storage but I can arrange viewing of this car by appointment to seriously interested people.
Absolutely no time wasters, dreamers or joy riders.
Will help with interstate transport if needed.
$26,500 ono
0448860080
What a beautiful car; I'd be heartbroken to let something like this go...
I'm sure you'll have no trouble finding it a home.
Thanks for the comments guy, it will be a very very sad sale but sometimes something has to give unfortunately. I just hope it gets respected and treated right, like it has been all its life so a quality and well maintained GTR can still be sourced in years to come.
Price drop.. $25,500.. Motivated seller.. Amazing GTR through out and had the money spent in the right areas !! Can arrange a HD video of the car inside and out for interested parties.. !!
  • 3 weeks later...
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
